1 páginas (11 elementos)
Length of a Matrix - Mensajes
OK, you are imitating MCD.
I'm trying to imitate Wolfram's Mathematica Append.
WroteI'm trying to imitate Wolfram's Mathematica Append.
Not that much miraculous Mathematica 4.0
Mathcad APENDPRN was almost never used.
Useful to compact/file a data set with wisely
collected the fitting coefficients.
On that application, Smath is far superior ... Explain
Smath can save same stuff + the formula ... WOW !
Saludad Alvaro [is that correct ?]
Page24 Alvaro.sm (15,01 KiB) descargado 1743 vez(es).
Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
The new indices are added expanding the matrix vertically; there is no special case for single-row matrices.
For your task, one way could be this:
Or this:
Or this:
Close. Correct it's Saludos Jean.
WroteYes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
Thanks for the explain. You give to me the rule for understand the result. Just as comment, matlab don't follow that, and gives this results:
Archivo no encontrado. Archivo no encontrado.
WroteJust as comment, matlab don't follow that, and gives this results:
What Matlab does Smath does as well with lot more user specifics.
Matlab => MDA [Muliti Dimensional Array]
Mathematica => Cell Array
They just have their system. I can do whatever from this example
and very quick too, just few more modules.
