Smath Studio 98.6606 closes unexpectedly
Smath Studio 98.6606 closes unexpectedly - Smath Studio quits unexpectedly when inserting a table and running the program - Mensajes
#1 Publicado: 5/2/2018 22:07:46
CBG
CBG
78 me gusta en 312 mensajes.
Smath Studio fails when a table containing arrays is inserted, and closes unexpectedly.
Test_Table.sm (6,37 KiB) descargado 1242 vez(es).
Carlos
Davide Carpi 7/2/2018 8:58:00
#2 Publicado: 5/2/2018 23:37:06
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
Hello CBG!
It works for me.
#3 Publicado: 6/2/2018 1:55:54
Hello CBG!
It works for me.
Carlos, try this
#4 Publicado: 6/2/2018 5:04:41
Grupo: Moderator
Carlos
Works with Portable 6484
Force Close with installed 6606.
#5 Publicado: 6/2/2018 5:24:53
127 me gusta en 342 mensajes.
It works for me too.
I note that the variables of Carlos are not in italic character.
#6 Publicado: 6/2/2018 8:47:42
Grupo: Moderator
Carlos
may be this helps better to understand the situation here.
correction: force close occurs if the first element of matrix is a string.
table_test2.sm (23,06 KiB) descargado 1362 vez(es).
#7 Publicado: 6/2/2018 13:38:28
CBG
CBG
Hello "ndtm", Jean, "overlord" and Sergio.
Thank you very much for your comments, recommendations, suggestions and help.
It seems that it is a Bug in Smath Studio 0.98.6606, since I tested it in the
versions of Smath Studio 0.98.6179, 98.6484 and 0.97.5346, and in
these versions it worked correctly.
Carlos
#8 Publicado: 6/2/2018 14:59:54
Grupo: Super Administrator
I can't reproduce this issue with 6606.
#9 Publicado: 6/2/2018 15:24:36
Did you try updated version of Table Region?
#10 Publicado: 6/2/2018 17:14:52
Grupo: Moderator
Here is the latest deal, I have created a portable 6606 version which has no extension plugin except table region.
Now the table plugin is working as it should be. Maybe one of the installed plugins is creating the havoc.
I am going to try to find it by installing one at a time.
#11 Publicado: 6/2/2018 17:31:16
CBG
CBG
By---->Andrey Ivashov
Yes I Yes, I did it
Carlos
Andrey Ivashov 6/2/2018 18:05:00
#12 Publicado: 6/2/2018 17:56:29
Grupo: Moderator
Andrey,
Could you please change your decimal symbol from comma to period and try to open the test file above?
I think I have found the culprit. When I change it to comma, no issues so far.
#13 Publicado: 6/2/2018 18:04:55
Thank you very much! I will check decimal symbol and will try to fix the plugin asap.
#14 Publicado: 6/2/2018 19:21:15
Issue is reproduced. Working to investigate and fix.
#15 Publicado: 6/2/2018 20:16:31
Please could you try to update plug-in and test your examples?
I think I have fixed the issue.
CBG 6/2/2018 20:42:00, Davide Carpi 7/2/2018 4:10:00
#16 Publicado: 6/2/2018 20:21:20
Grupo: Moderator
Table region is not causing force crash.
Everything seems good, congrats.
Andrey Ivashov 6/2/2018 20:22:00, CBG 6/2/2018 20:42:00
#17 Publicado: 6/2/2018 20:41:25
CBG
CBG
Now the example works very well.
Thank you very much.
Carlos
