Smath Studio 98.6606 closes unexpectedly
Smath Studio 98.6606 closes unexpectedly - Smath Studio quits unexpectedly when inserting a table and running the program - Сообщения
#1 Опубликовано: 05.02.2018 22:07:46
CBG
CBG
Smath Studio fails when a table containing arrays is inserted, and closes unexpectedly.
Test_Table.sm (6,37 КиБ) скачан 1219 раз(а).
Carlos
Davide Carpi 07.02.2018 08:58:00
#2 Опубликовано: 05.02.2018 23:37:06
NDTM Amarasekera
NDTM Amarasekera
Hello CBG!
It works for me.
#3 Опубликовано: 06.02.2018 01:55:54
Hello CBG!
It works for me.
Carlos, try this
#4 Опубликовано: 06.02.2018 05:04:41
599 сообщений из 1 381 понравились пользователям.
Carlos
Works with Portable 6484
Force Close with installed 6606.
#5 Опубликовано: 06.02.2018 05:24:53
It works for me too.
I note that the variables of Carlos are not in italic character.
#6 Опубликовано: 06.02.2018 08:47:42
Carlos
may be this helps better to understand the situation here.
correction: force close occurs if the first element of matrix is a string.
table_test2.sm (23,06 КиБ) скачан 1335 раз(а).
#7 Опубликовано: 06.02.2018 13:38:28
CBG
CBG
Hello "ndtm", Jean, "overlord" and Sergio.
Thank you very much for your comments, recommendations, suggestions and help.
It seems that it is a Bug in Smath Studio 0.98.6606, since I tested it in the
versions of Smath Studio 0.98.6179, 98.6484 and 0.97.5346, and in
these versions it worked correctly.
Carlos
#8 Опубликовано: 06.02.2018 14:59:54
2 343 сообщений из 4 055 понравились пользователям.
Группа: Super Administrator
I can't reproduce this issue with 6606.
#9 Опубликовано: 06.02.2018 15:24:36
Did you try updated version of Table Region?
#10 Опубликовано: 06.02.2018 17:14:52
Here is the latest deal, I have created a portable 6606 version which has no extension plugin except table region.
Now the table plugin is working as it should be. Maybe one of the installed plugins is creating the havoc.
I am going to try to find it by installing one at a time.
#11 Опубликовано: 06.02.2018 17:31:16
CBG
CBG
By---->Andrey Ivashov
Yes I Yes, I did it
Carlos
Andrey Ivashov 06.02.2018 18:05:00
#12 Опубликовано: 06.02.2018 17:56:29
Andrey,
Could you please change your decimal symbol from comma to period and try to open the test file above?
I think I have found the culprit. When I change it to comma, no issues so far.
#13 Опубликовано: 06.02.2018 18:04:55
Thank you very much! I will check decimal symbol and will try to fix the plugin asap.
#14 Опубликовано: 06.02.2018 19:21:15
Issue is reproduced. Working to investigate and fix.
#15 Опубликовано: 06.02.2018 20:16:31
Please could you try to update plug-in and test your examples?
I think I have fixed the issue.
CBG 06.02.2018 20:42:00, Davide Carpi 07.02.2018 04:10:00
#16 Опубликовано: 06.02.2018 20:21:20
Table region is not causing force crash.
Everything seems good, congrats.
Andrey Ivashov 06.02.2018 20:22:00, CBG 06.02.2018 20:42:00
#17 Опубликовано: 06.02.2018 20:41:25
CBG
CBG
Now the example works very well.
Thank you very much.
Carlos
