1 páginas (11 elementos)
Ode symbolic solution with IC - How to solve? - Mensajes
WroteSee please one ODE symbolic solution without IC
We have it done for exporting formula c/w constants & IC
ODE_Laplace 2nd [Type 3].sm (34,42 KiB) descargado 1215 vez(es).
Valery Ochkov 1/7/2023 9:20:00
WroteWroteSee please one ODE symbolic solution without IC
Thanks!
But no way to do so in SMath
WroteWroteThanks!
"L & m" are missing in dsolve result ?
m is missing in dsolve.
Hi Valery. Use Ctrl+Shift+K for write D(x)(0), which means x'(0)
Thanks!
dsolve-ICs.sm (10,61 KiB) descargado 1526 vez(es).
The distance between the cities added.
GravityTrain.sm (31,01 KiB) descargado 1448 vez(es).
GravityTrain.pdf (233,1 KiB) descargado 922 vez(es).
Valery Ochkov 3/7/2023 4:18:00
Earth distance companion added.
Sanity check Air Industry.
Angle Vincenty Earth Distance [Mike].sm (49,78 KiB) descargado 1210 vez(es).
WroteA pendulum ...
The exact solution needs some handwrite work.
Edited: a hard handwrite work. Previous version was wrong.
Correct solution -> pendulum v2.sm (13,73 KiB) descargado 1460 vez(es).
Wrong solution -> pendulum.sm (13,88 KiB) descargado 1468 vez(es).
Valery Ochkov 5/7/2023 6:23:00
