How to do in SMath? - Iteration from a set of data. - Mensajes
The aim is to obtain alpha and beta values from any intermediary values of H/L or H/l.
Thanks,
There are three different interpolation functions.
Your data seems to be lineear according to values.
Here is a demonstration of interpolation plots.
I also added functions to find β and α.
interpolation.sm (138,91 KiB) descargado 1307 vez(es).
A tank that has length 'L' has diameter as well.
You can only measure level from [0...1] empty/full.
That's what alpha/beta seem to represent.
If so, the system is the segment approximation.
This problem is solved in Smath 5 decimals [Tema, Perry]
The Smath document ignores the ends. You can roughly add.
Please, acknowledge for eventual completion of the project.
WroteYou can use interpolation functions for that.
Your data seems to be linear according to values.
Thank you, Overlord. Much appreciated.
Tim
WrotePossibly, there is a model ▼ function for these two
Thank you, Jean. "L" does not represent diameter. This table is for a rectangular tank design.
Tim
WroteThank you, Jean. "L" does not represent diameter. This table is for a rectangular tank design.
Tim
Obviously the data confirm the tank is not circular.
It may not be pure rectangular either vs deformation.
For + contribution, please don't hesitate.
WroteIt may not be pure rectangular either vs deformation.
There is a golden phrase for engineers:
When something is minor effecting overall outcome,
That condition/subject/aspect is negligible.
WroteObviously the data confirm the tank is not circular.
For contribution, please don't hesitate.
Page2 Table.sm (129,43 KiB) descargado 1498 vez(es).
