MicroOffice
MicroOffice - 🚧 Word, Excel and Visio - Mensajes
#1 Publicado: 15/8/2019 13:58:22
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
MicroOffice [ β ]
SMath Viewer compatibility mono compatibility Sources
Implementation started.
I don't know how, but I think it is possible to show office documents as images. For editing we can open Word, Excel or Visio as external editors. Documents can be embedded to worksheet.
frapuano 16/8/2019 3:02:00, Arie 16/8/2019 16:10:00, Николай Цопа 22/3/2020 14:10:00
#2 Publicado: 15/8/2019 18:27:29
Grupo: Moderator
Using this technique it is possible to use the Plotly.js library to draw graphs. Basically, this method allows you to access the usual form, but with limited interaction.
#3 Publicado: 29/9/2019 15:02:47
Grupo: Moderator
This will be a good plugin I think.
Is there any way to show the office document as objects, not as images?
In mathcad when I paste an excel table it is imported as an object.
It can be edited with right click and externally edited as you mentioned for your implementation.
But it is also shown as object and pdf-friendly.
smath.pdf (64,2 KiB) descargado 1130 vez(es).
mathcad.pdf (284,97 KiB) descargado 1013 vez(es).
#4 Publicado: 29/9/2019 17:04:42
If you want that Excel data table in Smath, easy:
1. capture the Execl, select, crop image
2. copy image, paste in Smath.
The tool is freeware WinGrab.
#5 Publicado: 29/9/2019 17:44:14
Grupo: Moderator
Jean, it is obvious you didn't check the pdf files. You really wouldn't need to tell me about how to crop images if you did, I already did that.
Problem is not how to do it, problem is font render quality. Smath copies excel tables as images, which has no font so no print quality.
1. there is undeniable quality difference between cropped image version (smath), which you mentioned, and font version (mathcad).
2. windows has its own screen capture program that works perfectly. no need to install or keep additional software for this purpose.
3. you actually don't need any software to copy image of excel tables, Ctrl+C is enough. than you can paste it as an image in smath.
But if you make pdf from smath file which has image copied excel table, quality is a disaster.
#6 Publicado: 29/9/2019 19:48:04
But if you make pdf from smath file which has image copied Excel table, quality is a disaster.
The two PDf look same [I checked both]
That's why I suggested NOT use Microsoft.
If I make an Smath PDF as captured, PDF is 1/1
My PDF is CutePDF freeware, NOT Smath PDF.
#7 Publicado: 29/9/2019 20:07:19
...open with Adobe Reader [the freeware]
Images captured/crop as described earlier,
pasted in Smath, Smath => CutePDF
Type T_J.pdf (399,6 KiB) descargado 1061 vez(es).
#8 Publicado: 29/9/2019 21:19:40
... so simple, so perfect for publishing Smath *.PDF
CosmosPDF.pdf (120,4 KiB) descargado 935 vez(es).
#9 Publicado: 30/9/2019 9:24:13
Grupo: Moderator
Please zoom in both pdf. You will see they are not same.
Your last example has the same diseas, if you zoom in to your cosmos.pdf you will see.
Texts in cropped images are not looking good at pdf and paper.
#10 Publicado: 30/9/2019 10:16:06
Grupo: Moderator
Unfortunately, no. As I know for good quality you must use .Net graphic library and there is no simple way to translate graphics from another application. In such projects, I try to find ways to use the existing code to expand the functionality of the program even if the quality of the document decreases. There are so many components that are based on the Control class, it would be great to use at least some of them. Because writing a useful plugin from scratch is very difficult.
overlord 30/9/2019 15:15:00
#11 Publicado: 30/9/2019 11:10:48
At right is the original in Smath document.
At left is the 100% Adobe, copied/pasted.
#12 Publicado: 30/9/2019 11:18:02
Smath document.
PDF Cosmos Test.sm (711,28 KiB) descargado 1761 vez(es).
After this post, I will re-download check.
#13 Publicado: 30/9/2019 11:30:01
... re-download sanity checked confirmed 1/1.
Conclusion:
1. NO need for Microsoft for Smath *.PDF
2. Go by the procedure explained above.
3. Procedure presumably applicable to Smath past SS 6179.
4. Check [3] on latest SS.
#14 Publicado: 30/9/2019 11:57:54
Simply, I don't understand what Microsoft has to do wrt Smath
I used only Paint in my Win 7, a damned poor Paint vs XP Home.
#15 Publicado: 30/9/2019 15:22:41
Grupo: Moderator
Thank you for your kind and explanatory reply. So I have to get on with images.
#16 Publicado: 30/9/2019 15:49:33
Have you tried: select the Excel table, copy/paste in IrfanView.
Does not => f..k Microsoft Office.
Since Mathcad 8 Pro. select math regions [including table]
copy/paste in IrfanView ... bingo as an image,
copy image, paste in Smath [PDF Cosmos].
I asked for same feature in Smath, apparently was to be
added in SS 6179 < SS Newer.
The alternate captured procedure offered ... few more clicks.
#17 Publicado: 30/9/2019 17:21:51
Grupo: Moderator
It is available since version 0.98.6523
#18 Publicado: 30/9/2019 18:27:50
... then Collab Overlord should try.
Thanks Davide.
#19 Publicado: 2/10/2019 15:43:06
Alexander O. Melnik
Alexander O. Melnik
127 me gusta en 498 mensajes.
Grupo: Moderator
EXCEL I/O plugin will plot regions of excel for you without quality loss by using excel_EMF(#) function
https://en.smath.com/forum/yaf_postst4375_Plugin---EXCEL--2003--I-O-with-recalculation-and-export-to-PNG.aspx
A sample of a Plot produced by combination of excel_EMF function and Image Region inside the SMath workbook.
The example was borrowed from one of the calculations by Jean Giraud.
Note the difference of as-printed quality between X-Y Plot output and excel_EMF output.
Archivo no encontrado.Archivo no encontrado.Archivo no encontrado.
overlord 2/10/2019 18:28:00
#20 Publicado: 2/10/2019 18:36:35
Grupo: Moderator
This has much more render quality than I expected, actually there is no quality loss. Thank you very much.
If combination of excel_IO and image plugin can do this, there should be no reason MicroOffice plugins can't imho.
Smath can even store excel data embedded in *.sm file and it can be viewed without quality loss like your example.
So there won't be any need for an excel file (as a source) for viewing.
