Implicit Plot
Implicit Plot - Mensajes
#1 Publicado: 19/2/2018 0:34:45
Hi. I'm trying to implement this implicit plot. But can't "cut" the lines in the xy plot. Also, any help about speeding the function is welcome.
iplotq.sm (40,7 KiB) descargado 1820 vez(es).
#2 Publicado: 19/2/2018 4:35:55
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
Try the method of Draghilev
DragilevMet.sm (24,09 KiB) descargado 1260 vez(es).
#3 Publicado: 19/2/2018 6:07:23
Hi Ber. Thanks for the implementation. But it use maple and is semisymbolic, I want just some that can works in the cloud, like: https://en.smath.info/cloud/sheet/s23Pa6bZUn
#4 Publicado: 19/2/2018 6:38:09
Fridel Selitsky
Fridel Selitsky
Option without Maple
DragilevMet1.sm (21,62 KiB) descargado 1296 vez(es).
frapuano 19/2/2018 7:15:00
#5 Publicado: 19/2/2018 7:13:37
Perfect! Thanks.
#6 Publicado: 19/2/2018 19:22:41
CBG
CBG
78 me gusta en 312 mensajes.
Not graphic
It does not show any error
Carlos
#7 Publicado: 19/2/2018 21:28:12
Hi Carlos
For see the error message type B1=
#8 Publicado: 19/2/2018 23:44:57
CBG
CBG
Hello Alvaro:
Thank you very much.
The error in the graph is that x is not defined.
What causes this error?
In the graphs published by you it is seen that graphs correctly.
Carlos
#9 Publicado: 22/2/2018 3:11:16
Hola Carlos. Try the following, a short version, just for n=2.
DragilevMet2.sm (12,74 KiB) descargado 1251 vez(es).
Fridel Selitsky 22/2/2018 4:44:00
#10 Publicado: 22/2/2018 4:21:24
Fridel Selitsky
Fridel Selitsky
Try also the old version of the Draghilev method
DragilevMet3.sm (23,18 KiB) descargado 1242 vez(es).
Razonar,thanks for the short code for n = 2
#11 Publicado: 22/2/2018 14:45:42
Carlos, Alvaro,
From previous use of Dragilev method, I observed great difficulties
to appropriately start/stop rkfixed. Your example above works fine as is.
For more points with less tentatives in specific cases, the easiest way
is to pass it to the closed shape Hermite suite.
I should revisit some of those examples.
The Esplina AI2000 interpolates as well for closed shapes.
Spline Esplina [AI2000].sm (21,79 KiB) descargado 1049 vez(es).
Spline Esplina [Hermite].sm (35,44 KiB) descargado 1041 vez(es).
Fridel Selitsky 22/2/2018 15:50:00
#12 Publicado: 22/2/2018 15:55:44
CBG
CBG
By--> Razonar
Citar
By--> Ber7
Citar
Try also the old version of the Dragilev method
DragilevMet3.sm (24kb) downloaded 10 time(s)
Hola Alvaro, Hello Ber7,
Thanks for your reply, but the DragilevMet2 and 3 files do not work.
The file of Ber 7 does not show any error, but by requiring the value
of B1 and B2, it says that "x" is not defined.
Attached drawing of the errors.
Hello Jean, your files worked perfectly.
Carlos
#13 Publicado: 23/2/2018 3:19:44
Hola Carlos.
It's because a problem with rkfixed routine in your environment. Try to download this, or use it in the cloud: DM_RK
#14 Publicado: 23/2/2018 15:56:57
CBG
CBG
Hola Alvaro:
Gracias por tu respuesta.
Thanks for your answer, but I found the fault.
The interference is caused by the Maxima Plugin,
by disabling it, the file works correctly.
Carlos
#15 Publicado: 23/2/2018 23:30:39
CBG
CBG
Hola Alvaro
Here too, the problem is caused by the decimal separator "Point",
Changing in options, the decimal separator from "Point" to "Comma", (from "." To ",")
resolves the problem of graphing
Carlos
Alvaro 24/2/2018 18:48:00
