exponential function error - Result is above the max. allowed positive number error - Mensajes
I'got the error, "Result is above the max. allowed positive number error" during exponential calculation.
How I resolve this kind of errors?
Thank you!
M.S.
exponential_max_err_v0.sm (12,83 KiB) descargado 1161 vez(es).
WroteHow I resolve this kind of errors?
... like this: index 'j' to de-confuse 'i' imaginary.
exponential_max_err_v0.sm (12,26 KiB) descargado 1151 vez(es).
WroteDear masters,
Hi. Summatorie ranged have some issues. For instance, the range variable isn't local. With eval you can get punctual results, but this version can't be plotted, and I don't know why:
Whith this other version you can do both things:
Hope that this helps.
exponential_max_err_v0.sm (13,37 KiB) descargado 1201 vez(es).
1. local definition mode
2. index piece wise
exponential_max_err_v0 (1).sm (24,22 KiB) descargado 1179 vez(es).
Wrotebut this version can't be plotted, and I don't know why:
... code this to the previous doctored document.
Summation operator is very capricious, but works
and plot scalar as demonstrated. Plot scalar for
lot more involved stuff [Budapest 39, Legendere ...]
Remember Alvaro: you doctored my Barnes Hypergeometric !
But I have a still same problem.
Here are another sample file.
exponential_max_err_v03.sm (18,91 KiB) descargado 1182 vez(es).
WroteDear masters,
Thank you!
M.S.
I am getting error "Result is above max allowed positive number",too! And l don't know how to solve it.
I think something is wrong here in the numeric/symbolic engine of SMath which causes those errors.
Version "0.99.7109"
I can not understand this
WroteThank you your replies.
But I still have same problem.
Hello Novice ...
I can't see what you are attempting.
Are you trying to fit a model function to a data set ?
If so: just attach the data set, some smart cat will exercise.
A maths document that has no hint about ... Oh !
WroteI think something is wrong here in the numeric/symbolic engine of SMath which causes those errors.
Version "0.99.7109"
From observation in many more SS 7109, the indexing is freaked.
Doctored in pink SS 6179.
exponential_max_err_v03.sm (17,79 KiB) descargado 1148 vez(es).
I'm just doing the calculation of an ANS standard example.
I think this problem is a kind of overflow of exponential function.
As you know if X is greater than the 709.783 then the value of exp(X) is overflown.
So I believe that SMath should do something to check the nominal boundaries of special functions (exponential, logarithmic etc.)
Thank you!
regards,
MS
WroteI think this problem is a kind of overflow of exponential function.
Thank you!
Thanks for the hint.
Functions that overflow can be managed otherwise.
About that project, just give the X,Y data you want to fit.
Smath reports overflow as "max value ..."
All those math functions aren't Smath, rather from numerical library
as implemented in Microsoft and other maths tools.
Ah! I can see XY pairs coming soon.
WroteWroteI think something is wrong here in the numeric/symbolic engine of SMath which causes those errors.
Version "0.99.7109"
Still confused...
exponential_max_err_v03-corr.sm (31,47 KiB) descargado 1180 vez(es).
WroteStill confused...
Doctored a bit SS 6179 ... No red in No time.
exponential_max_err_v03-corr.sm (32,81 KiB) descargado 1163 vez(es).
WroteDoctored a bit SS 6179 ... No red in No time.
... from there => what's next step ?
exponential_max_err_v03-corr [Next].sm (39,26 KiB) descargado 1023 vez(es).
Wrote... from there what's next =
... does the suite in green makes sense ?
That mystic formula has to be put in executable maths
exponential_max_err_v03-corr [Next-Suite].sm (160,47 KiB) descargado 1078 vez(es).
WroteThat mystic formula has to be put in executable maths
Please, check my interpretation.
exponential_max_err_v03-corr [Next-Suite].sm (185,37 KiB) descargado 1013 vez(es).
WroteWroteStill confused...
Still red for me...
WroteStill red for me...
Radovan, mon ami ... you must feel Sysyphus on that boulder !
I figure the all project is as simple as in the attached SS 6179.
Novice didn't give enough ... wait and see.
On the other hand your red is for Grand Doctor Andrey.
Fission.sm (133,59 KiB) descargado 1128 vez(es).
