Thiele Function Automation
Thiele Function Automation - Automation of the Thiele function - Mensajes
#1 Publicado: 30/4/2018 17:45:46
CBG
CBG
78 me gusta en 312 mensajes.
This example is an automation of the Thiele function
published by Jean in the "Utilities Pts logpts Application" sheet
Thiele_Automatic_Jean_cbg.sm (22,08 KiB) descargado 1264 vez(es).
Carlos
#2 Publicado: 1/5/2018 19:33:59
... refreshed a bit, a note added.
Superb, the piece of automated interpolation.
Thanks Carlos ... Jean
Thiele_Automatic_Jean_cbg.sm (26,85 KiB) descargado 1269 vez(es).
#3 Publicado: 2/5/2018 18:23:05
CBG
CBG
Hello Jean,
Please review the following example that you posted.
Thiele Model Construct.sm (44,15 KiB) descargado 1286 vez(es).
Thank you
Carlos
#4 Publicado: 3/5/2018 10:37:19
Hello Jean,
Hello Carlos,
The attached document has been doctored.
The long native form is as nice to export than the reduced J_Frac.
J_Frac is more compact, but not as clear for unfamiliar user.
Thiele is capricious wrt to Maple [see the blue note].
It starts refusing if too many Maple instances have been invoked,
maybe a limited courtesy from Maplesoft ?
Please let me know if correct in your Smath system.
See you soon ... Jean
From fresh Smath session, supports the 3 documents attached.
Thiele_0 Demo.sm (57,41 KiB) descargado 1241 vez(es).
Thiele Transit_Convert.sm (13,57 KiB) descargado 1262 vez(es).
Thiele Model Construct Copy.sm (37,77 KiB) descargado 1264 vez(es).
#5 Publicado: 9/5/2018 18:39:36
CBG
CBG
Hello Jean
Updated version of Interpolation using the Thiele algorithm in cuntinuous fractions.
It includes the calculation of the inverse differences φ [x0, ..., xi], obtained from the values in the known points
Rounding the values of the inverse differences for the purpose of presenting the equation to make it shorter
Thiele_Automatic_Jean_CBG_R1.sm (69,59 KiB) descargado 1310 vez(es).
Carlos
#6 Publicado: 10/5/2018 10:37:06
Hello Carlos,
What a delicious/educative/Engineering piece of work ... zillions thanks !
Reshaped a bit for first time readers.
Thiele_3 Automatic [on error Carlos].sm (36,97 KiB) descargado 1058 vez(es).
