Fractal Tree
Fractal Tree - a programme for displaying a fractal tree - Mensajes
#1 Publicado: 15/3/2020 14:48:37
Gerard Bush
Gerard Bush
8 me gusta en 9 mensajes.
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7,93 KiB) descargado 1391 vez(es).
fractal tree.pdf (209,83 KiB) descargado 863 vez(es).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Davide Carpi 16/3/2020 12:19:00
#2 Publicado: 15/3/2020 18:30:25
Like this ... in ½ points.
fractal tree.sm (11,31 KiB) descargado 1384 vez(es).
#3 Publicado: 16/3/2020 7:13:02
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17,6 KiB) descargado 1320 vez(es).
Gerard Bush 16/3/2020 8:25:00, Davide Carpi 16/3/2020 12:19:00
#4 Publicado: 16/3/2020 8:16:56
Gerard Bush
Gerard Bush
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18,39 KiB) descargado 1319 vez(es).
#5 Publicado: 16/3/2020 9:04:22
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12,54 KiB) descargado 1323 vez(es).
A 5 usuarios les gustó este mensaje
Davide Carpi 16/3/2020 12:19:00, Alvaro 17/3/2020 16:15:00, Вячеслав Мезенцев 16/3/2020 13:59:00, frapuano 16/3/2020 9:35:00, Gerard Bush 16/3/2020 10:55:00
#6 Publicado: 16/3/2020 17:55:35
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11,2 KiB) descargado 1333 vez(es).
Pattern Frieze Heppi.sm (11,97 KiB) descargado 1356 vez(es).
Pattern Hilbert.sm (8,53 KiB) descargado 1309 vez(es).
Pattern Patch Work.sm (10,92 KiB) descargado 1346 vez(es).
Pattern Fractal Sierpinski.sm (10,92 KiB) descargado 1373 vez(es).
Pattern Snail.sm (26,85 KiB) descargado 1356 vez(es).
Pattern Fern.sm (19,4 KiB) descargado 1365 vez(es).
Pattern Sierpinski Kover.sm (16,72 KiB) descargado 1342 vez(es).
Pattern Etoile Magic [Short].sm (46,69 KiB) descargado 1145 vez(es).
Pattern Sierpinski Triangles.sm (35,21 KiB) descargado 1328 vez(es).
Pattern Prototile.sm (116,5 KiB) descargado 1409 vez(es).
#7 Publicado: 16/3/2020 17:59:14
Pattern PythagorasTree.sm (6,99 KiB) descargado 1376 vez(es).
#8 Publicado: 17/3/2020 15:24:27
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11,03 KiB) descargado 1128 vez(es).
Gerard Bush 18/3/2020 9:56:00
#9 Publicado: 18/3/2020 9:58:54
Gerard Bush
Gerard Bush
Thank you very much, Jean and Ber7 for your additions!
#10 Publicado: 18/3/2020 12:06:31
Fridel Selitsky
Fridel Selitsky
Fractal tree with leaves
Pattern fractal 3.sm (12,01 KiB) descargado 1336 vez(es).
Davide Carpi 18/3/2020 15:07:00, Gerard Bush 18/3/2020 16:59:00, NDTM Amarasekera 19/3/2020 6:03:00
