Currency Units plugin
Currency Units plugin - Add currencies and real-time exchange rates in SMath Studio. - Messages
#1 Posted: 12/16/2013 8:01:40 PM
1,442 likes in 2,935 posts.
Hi all,
Here there is a plugin to have currencies and exchange rates in SMath Studio.
Infos:
Functions:
  • SetCurrencyUnits(1), SetCurrencyUnits(2): extends SMath Studio with currency units. When an internet connection is available, exchange rates are kept updated using the ECB reference rates (internet connection not required but useful);
    Quote
    The reference rates are usually updated by 3 p.m. C.E.T. They are based on a regular daily concertation procedure between central banks across Europe and worldwide, which normally takes place at 2.15 p.m. CET.
  • GetYahooExchangeRate(2): get a wide set of exchange rates from Yahoo Finance (internet connection required); service discontinued by Yahoo
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Andrey Ivashov 12/17/2013 6:52:00 PM, Martin Kraska 12/17/2013 3:24:00 AM, Вячеслав Мезенцев 12/18/2013 2:32:00 AM
#2 Posted: 12/16/2013 8:35:09 PM
1,353 likes in 2,265 posts.
Nice work, Davide. However, does not work with , as decimal separator.
#3 Posted: 12/16/2013 9:05:39 PM
Thank you Martin, try with the update
#4 Posted: 12/17/2013 3:23:36 AM
Better now, but still no connectivity. I guess that is sort of firewall or proxy issue.
#5 Posted: 12/17/2013 6:00:17 AM
Unfortunately Davide, this does not work for me (Win7 x64). Plugin refuses to install properly.
#6 Posted: 12/17/2013 8:07:23 AM
ok... as for now the password is: TEST
Try again, I've made some changes... If doesn't work try NetTest(0) and NetTest(1) and post a screenshot
very strange... try again with this update; if doens't work got to %APPDATA%\SMath\Debug\CurrencyUnits and post the log file
#7 Posted: 12/17/2013 8:41:16 AM
The results were overly wide, thus i cut them.
#8 Posted: 12/17/2013 8:41:47 AM
Failed again
Here is the log file
log.txt (1.76 KiB) downloaded 1208 time(s).
#9 Posted: 12/17/2013 11:09:29 AM
seems a proxy/firewall authorization problem... I suppose that NetTest("http://www.google.com") and NetTest("http://www.google.de") will produce the same results
Failed again
I've made another little modification, could you try again?
#10 Posted: 12/17/2013 1:31:12 PM
It seems that this plugin is not going to install into the Martins' unofficial build. I figured out by the second line of the log file.
I tried it on the official one and it seems to be Ok
Davide Carpi 12/17/2013 1:50:00 PM
#11 Posted: 12/17/2013 1:52:02 PM
thank you Radovan, now I understand
the plugin looks for the files in the %APPDATA% folder, I'll try to fix it
[EDIT] UPDATED: this version should work properly both in the official and the unofficial versions
Radovan Omorjan 12/17/2013 3:08:00 PM
#12 Posted: 12/17/2013 3:08:09 PM
Yes it works, thank you
#13 Posted: 12/17/2013 5:30:14 PM
In our school LAN, the connectivity is broken, at home web access works (official and unofficial version). I shall include the plugin in the next release of the inofficial distribution.
Davide Carpi 12/17/2013 10:08:00 PM
#14 Posted: 12/17/2013 10:14:35 PM
UPDATED
- error handling: LOGs will be placed in the relative "extensions\debug\CurrencyUnits" folder (so the portable version has a portable debug path)
- For developers only: added a log tool to output a Term[] tree representation (see the CurrencyUnits Implementer.cs).
2013-12-18 17_05_51-C__Users_Davide_AppData_Roaming_SMath_extensions_debug_CurrencyUnits_log.txt - N.png
#15 Posted: 1/3/2014 8:36:49 PM
UPDATED
- checks for network availability before each ECB update attempt;
- LOG tools updated (session start is no longer registered)
- NetTest() removed.
#16 Posted: 9/5/2018 7:22:04 AM
The yahoo download service for exchange rates has been discontinued. See their forum post.
Therefore, the function GetYahooExchangeRate() reports that the remote name could not be resolved.
I recommend to adjust the error message to "Service discontinued by Yahoo. Use function .... instead."
Perhaps some other source is available in replacement. However, I would not push this, because I rarely use it. Just cleaning up documentation.
Edit: filed as SS-3559
Davide Carpi 9/5/2018 2:01:00 PM
#17 Posted: 10/23/2018 7:59:34 PM
PLUGIN UPDATED SMath Studio 0.99.6839 and later
  • [SS-3560] restored unit as input argument in SetCurrencyUnits();
  • [SS-3559] since Yahoo service is discontinued now GetYahooExchangeRate() is hidden in the dynamic assistance and returns directly an error message if called;
#18 Posted: 3/27/2021 12:39:45 PM
PLUGIN UPDATED SMath Studio 0.99.7739 Nightly Build and later
  • added Currency units (symbols) toolbox;
NOTE:
  • symbols are sorted by unicode code;
  • symbols are subject to font implementation;
  • these are decorative symbols; you have to define yourself exchange rates on the worksheet to mix them;
