Currency Units plugin
Currency Units plugin - Add currencies and real-time exchange rates in SMath Studio. - Сообщения
#1 Опубликовано: 16.12.2013 20:01:40
Hi all,
Here there is a plugin to have currencies and exchange rates in SMath Studio.
Infos:
Functions:
  • SetCurrencyUnits(1), SetCurrencyUnits(2): extends SMath Studio with currency units. When an internet connection is available, exchange rates are kept updated using the ECB reference rates (internet connection not required but useful);
    Цитата
    The reference rates are usually updated by 3 p.m. C.E.T. They are based on a regular daily concertation procedure between central banks across Europe and worldwide, which normally takes place at 2.15 p.m. CET.
  • GetYahooExchangeRate(2): get a wide set of exchange rates from Yahoo Finance (internet connection required); service discontinued by Yahoo
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Andrey Ivashov 17.12.2013 18:52:00, Martin Kraska 17.12.2013 03:24:00, Вячеслав Мезенцев 18.12.2013 02:32:00
#2 Опубликовано: 16.12.2013 20:35:09
Nice work, Davide. However, does not work with , as decimal separator.
#3 Опубликовано: 16.12.2013 21:05:39
Thank you Martin, try with the update
#4 Опубликовано: 17.12.2013 03:23:36
Better now, but still no connectivity. I guess that is sort of firewall or proxy issue.
#5 Опубликовано: 17.12.2013 06:00:17
Unfortunately Davide, this does not work for me (Win7 x64). Plugin refuses to install properly.
#6 Опубликовано: 17.12.2013 08:07:23
ok... as for now the password is: TEST
Try again, I've made some changes... If doesn't work try NetTest(0) and NetTest(1) and post a screenshot
very strange... try again with this update; if doens't work got to %APPDATA%\SMath\Debug\CurrencyUnits and post the log file
#7 Опубликовано: 17.12.2013 08:41:16
The results were overly wide, thus i cut them.
#8 Опубликовано: 17.12.2013 08:41:47
Failed again
Here is the log file
log.txt (1,76 КиБ) скачан 1533 раз(а).
#9 Опубликовано: 17.12.2013 11:09:29
seems a proxy/firewall authorization problem... I suppose that NetTest("http://www.google.com") and NetTest("http://www.google.de") will produce the same results
Failed again
I've made another little modification, could you try again?
#10 Опубликовано: 17.12.2013 13:31:12
It seems that this plugin is not going to install into the Martins' unofficial build. I figured out by the second line of the log file.
I tried it on the official one and it seems to be Ok
Davide Carpi 17.12.2013 13:50:00
#11 Опубликовано: 17.12.2013 13:52:02
thank you Radovan, now I understand
the plugin looks for the files in the %APPDATA% folder, I'll try to fix it
[EDIT] UPDATED: this version should work properly both in the official and the unofficial versions
Radovan Omorjan 17.12.2013 15:08:00
#12 Опубликовано: 17.12.2013 15:08:09
Yes it works, thank you
#13 Опубликовано: 17.12.2013 17:30:14
In our school LAN, the connectivity is broken, at home web access works (official and unofficial version). I shall include the plugin in the next release of the inofficial distribution.
Davide Carpi 17.12.2013 22:08:00
#14 Опубликовано: 17.12.2013 22:14:35
UPDATED
- error handling: LOGs will be placed in the relative "extensions\debug\CurrencyUnits" folder (so the portable version has a portable debug path)
- For developers only: added a log tool to output a Term[] tree representation (see the CurrencyUnits Implementer.cs).
2013-12-18 17_05_51-C__Users_Davide_AppData_Roaming_SMath_extensions_debug_CurrencyUnits_log.txt - N.png
#15 Опубликовано: 03.01.2014 20:36:49
UPDATED
- checks for network availability before each ECB update attempt;
- LOG tools updated (session start is no longer registered)
- NetTest() removed.
#16 Опубликовано: 05.09.2018 07:22:04
The yahoo download service for exchange rates has been discontinued. See their forum post.
Therefore, the function GetYahooExchangeRate() reports that the remote name could not be resolved.
I recommend to adjust the error message to "Service discontinued by Yahoo. Use function .... instead."
Perhaps some other source is available in replacement. However, I would not push this, because I rarely use it. Just cleaning up documentation.
Edit: filed as SS-3559
Davide Carpi 05.09.2018 14:01:00
#17 Опубликовано: 23.10.2018 19:59:34
PLUGIN UPDATED SMath Studio 0.99.6839 and later
  • [SS-3560] restored unit as input argument in SetCurrencyUnits();
  • [SS-3559] since Yahoo service is discontinued now GetYahooExchangeRate() is hidden in the dynamic assistance and returns directly an error message if called;
#18 Опубликовано: 27.03.2021 12:39:45
PLUGIN UPDATED SMath Studio 0.99.7739 Nightly Build and later
  • added Currency units (symbols) toolbox;
NOTE:
  • symbols are sorted by unicode code;
  • symbols are subject to font implementation;
  • these are decorative symbols; you have to define yourself exchange rates on the worksheet to mix them;
