wfile function fractional output
wfile function fractional output - Messages
#1 Posted: 4/4/2019 4:00:47 AM
koraykadas
koraykadas
0 likes in 2 posts.
Hi Everybody,
I am trying to export (i.e., write to a text file) a vector of decimal numbers. With wfile function, I am only able to get fractional representation of data available. Is it possible to export numbers in decimal format only or should I convert them in Excel manually at the moment?
I will appreciate any other suggestion (other plugin or function) as an alternative.
#2 Posted: 4/4/2019 5:11:31 AM
118 likes in 336 posts.
You can use the "Data Exchange" plugin -> "ExportData.CSV" function
#3 Posted: 4/4/2019 5:46:04 AM
koraykadas
koraykadas
0 likes in 2 posts.
Solved. Many Thanks Sergio
#4 Posted: 4/4/2019 8:31:27 AM
If the data 'frac' is long enough, Ω will show truncated
enclose [Ω]= for full length ... [,] from matrix palette 1 row, 1 col.
