at function in SMath
at function in SMath - Messages
#1 Posted: 6/7/2023 11:25:18 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Hello!
What is the advantage of at function in SMath ?
Appreciate if any useful example is provided.
Cheers !
#2 Posted: 6/7/2023 12:34:30 PM
1,105 likes in 1,778 posts.
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's f /. x -> a notation, and perhaps there you can see how those programs use it and get a better idea of what it might be useful for. I also remember that den derive, which did not have a function like at, could be used instead ... take the limit: lim f for x -> a
#3 Posted: 6/7/2023 2:01:37 PM
NDTM Amarasekera
NDTM Amarasekera
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's [b]f /. x -
Hi Alvaro, thank you very much for your kind sentiments and valuable clarifications.
#4 Posted: 6/7/2023 3:19:06 PM
1,350 likes in 2,262 posts.
Handbook page for at() and Solve(). at() is a convenient alternative for Assign(), which creates assignments based on equations (as returned by Solve, ODE2 or Fit())
at.sm (22.23 KiB) downloaded 1030 time(s).
_Solve.sm (33.17 KiB) downloaded 1073 time(s).
#5 Posted: 6/7/2023 4:48:46 PM
Some demo application.
Take care ... Jean.
Solve at(2), at(3).sm (30.21 KiB) downloaded 1031 time(s).
#6 Posted: 6/7/2023 6:04:21 PM
Electron function added Φ(x,y)
This function has no symbolic solution.
It plots X_Y but for QuickPlot, you need solving.
Solve at(2), at(3).sm (47.5 KiB) downloaded 1060 time(s).
#7 Posted: 6/7/2023 11:33:01 PM
NDTM Amarasekera
NDTM Amarasekera
Thank you all for the clarifications and examples
