String to Variable Name (str2var)
String to Variable Name (str2var) - Messages
#1 Posted: 12/31/2022 2:33:45 AM
Mark R Harris
Mark R Harris
4 likes in 90 posts.
Is there a function or method that would allow a string (or variable name) located in a matrix element to be used as the name to define a variable?
Something like this:
Thank you!
#2 Posted: 12/31/2022 4:28:45 AM
1,544 likes in 1,858 posts.
4 users liked this post
Mark R Harris 12/31/2022 6:43:00 AM, NDTM Amarasekera 12/31/2022 10:10:00 AM, overlord 1/1/2023 3:20:00 PM, sergio 12/31/2022 8:09:00 AM
#3 Posted: 12/31/2022 6:43:07 AM
Mark R Harris
Mark R Harris
Thank you so much uni!
#4 Posted: 1/1/2023 12:51:50 PM
Laurent Fournier
Laurent Fournier
9 likes in 66 posts.
WOW!!!
#5 Posted: 1/2/2023 6:31:00 AM
1,350 likes in 2,262 posts.
You can also use the Assign() function of the Maxima Plugin (this should work even without Maxima installed).
It converts boolean equations into assignments.
In the case of strings you still need to apply str2num()
Assign.sm (4.75 KiB) downloaded 1019 time(s).
sergio 1/2/2023 7:35:00 AM, Mark R Harris 1/2/2023 5:02:00 PM
#6 Posted: 1/4/2023 8:02:47 PM
Mark R Harris
Mark R Harris
Some odd behavior here. When the "=" evaluation is removed the Assign() function breaks:
Assign odd behaviour.sm (3.14 KiB) downloaded 998 time(s).
Any thoughts?
I'm hoping to be able to assign multiple variables from a matrix like this:
Assign For Loop Broken.sm (5.11 KiB) downloaded 970 time(s).
#7 Posted: 1/4/2023 9:47:22 PM
churichuro
churichuro
29 likes in 79 posts.
a small workaround, could be to place the for inside a line command and return a false token value, it is not very clean but it works as far as I can see.
I think the assign command is not evaluated immediately, but has a delayed evaluation, which somehow only takes place after using the "=" symbol.
Mark R Harris 1/4/2023 10:04:00 PM
#8 Posted: 1/5/2023 11:30:01 AM
596 likes in 1,373 posts.
Assign() is a useful function and it doesn't need Maxima as you have indicated.
I don't (can't) use Maxima but I need Assign() sometimes.
And its codes have zero relation with Maxima functions.
This is why I suggested sometime ago that it could have relocated in another collective plugin.
CustomFunctions plugin is a good candidate for this purpose.
But I am not persistence, it is what it is.
Author of these plugins choose it this way.
Mark R Harris 1/5/2023 6:24:00 PM
#9 Posted: 1/5/2023 4:57:04 PM
Any thoughts?
Two hints:
- The Assign function needs to be executed in order to do it's work, either by assigning the result to some dummy variable or by requesting display of the result.
- You don't need a loop, Assign() can handle vector arguments
Blatt10.sm (5.31 KiB) downloaded 1026 time(s).
#10 Posted: 1/5/2023 5:22:41 PM
In general I don't care where Assign() is defined. It is in the Maxima plugin, because I needed a neat way to make use of results from Maxima functions like algebraic or ode solvers.
Yet I don't think that it would be a good idea to remove functions from plugins, because this would break the dependency management of existing sheets.
I don't know what happens if the same function is defined in multiple plugins. Would SMath crash? If not, which definition is used if both plugins are installed? One would see this in the dynamic help, but how to control?
BTW, I think that some day I'll revisit the Maxima plugin and if I get some help with a linux development tool chain and work flow I could perhaps make the plugin work also under linux. But that would require at least two months of full time work without distractions, because I would need to learn C# anew from scratch.
If someone is a master in C# I am happy to assist in refactoring and bug fixing of the plugin by providing the specifications and unit tests.
I'd be more comfortable with python or javascript but to my knowledge these aren't options for making plugins.
Mark R Harris 1/5/2023 6:25:00 PM
#11 Posted: 1/6/2023 2:15:05 AM
1,105 likes in 1,778 posts.
Hi. This could be another option.
MyAssign 2.sm (10.52 KiB) downloaded 991 time(s).
7 users liked this post
⚜ Kenny Lemens, P.E. ᵂᴵ 2/27/2023 12:19:00 PM, Вячеслав Мезенцев 1/6/2023 7:07:00 AM, NDTM Amarasekera 1/6/2023 12:57:00 PM, sergio 1/6/2023 2:23:00 PM, churichuro 1/6/2023 4:19:00 PM, bdrunagle 1/6/2023 4:21:00 PM, Mark R Harris 1/6/2023 4:41:00 PM
#12 Posted: 1/6/2023 4:25:18 PM
churichuro
churichuro
@Razonar, as usual with you, you give imaginative and useful solutions, it's great when people share their knowledge and help others, and with such a high technical level. thanks and congratulations.
I have a folder on my computer exclusively for the spreadsheets you share.
Mark R Harris 1/6/2023 5:15:00 PM, Alvaro 1/6/2023 11:10:00 PM
#13 Posted: 1/6/2023 4:42:15 PM
Arie
Arie
94 likes in 285 posts.
In the event you may want to add descriptions to these definitions... a related thread:
https://en.smath.com/forum/yaf_postst23228_Assign-Description-to-Variable.aspx
It's a work around, but potentially useful.
Alvaro 1/6/2023 11:10:00 PM, sergio 1/7/2023 7:09:00 AM, Mark R Harris 1/6/2023 4:50:00 PM
#14 Posted: 1/6/2023 4:43:00 PM
Mark R Harris
Mark R Harris
Yes indeed. Likewise. What churichuro said!
#15 Posted: 1/6/2023 11:11:34 PM
Thanks guys. I sincerely appreciate that.
