Pipe Network Analysis
Pipe Network Analysis - Solution by loop method - Messages
#1 Posted: 4/14/2016 2:36:18 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Examples of a problem solved in SS and Excel are attached.
The results are tallying.
Pipe Network Ex3.1.sm (417.66 KiB) downloaded 1513 time(s).
Pipe Network by Solver Ex3.xlsx (301.19 KiB) downloaded 1124 time(s).
Alexander O. Melnik 4/14/2016 2:10:00 PM
#2 Posted: 4/14/2016 3:15:44 AM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
IMHO, in this case the EXCEL solution is "cleaner".
EXCEL shines when you need to process simple formulae applicable to many rows of data... Which we do have in this case.
#3 Posted: 4/14/2016 10:47:43 AM
The problem is not to insist to expand symbolic. If you were scared of that one,
you have seen nothing compared to > 12 pages wide expansion. Before expanding,
hover Unknown(F) and see if it is of any profitable use.
Davide Carpi 4/14/2016 3:22:00 PM
#4 Posted: 4/14/2016 10:49:59 AM
... forgot to attach WS.
Pipe Network.sm (194.18 KiB) downloaded 1297 time(s).
Davide Carpi 4/14/2016 3:22:00 PM, frapuano 4/14/2016 5:15:00 PM
#5 Posted: 5/2/2016 10:10:30 PM
Gilberto E. Urroz
Gilberto E. Urroz
22 likes in 36 posts.
Check out Lectures 14b-20 in this website:
http://www.neng.usu.edu/cee/faculty/gurro/Classes/Classes_Spring2013/CEE3510_Spring2013/CEE3510_Schedule.htm
EPANET is the easiest way to solve pipe networks
#6 Posted: 5/3/2016 10:53:06 AM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Multiple software to do this. Pipe-flo, AFT Fathom, and others come to mind. If memory serves, the hydraulic institute and a limited node software to do this too.
http://www.pumps.org/Training/Free_Pump_Software.aspx
With that said, I still like to do things on SMath/MathCAD to verify results, since I can "see" the math.
#7 Posted: 5/3/2016 11:32:51 AM
Can't be more right than checking the maths for documenting the project(s).
Elsid, as a byside question: is your Mathcad 15 working ?
My Google web site is still active "mathengjmg". I can see it all, but
since PTC deactivated [scrapped] Mathcad 11 Single User Edition, if I
download any of the 663 work sheets [100MB], none will open.
Would you be kind enough to download some work seets and let me know
if they open in your Mathcad 15 ?
Thanks, Jean
https://sites.google.com/site/mathengjmg[/url]
#8 Posted: 5/3/2016 1:59:56 PM
Ruben Sidranski
Ruben Sidranski
Jean,
I sent private Message
#9 Posted: 5/3/2016 8:09:00 PM
Jean,
Thanks Elsid, I replied.
