Pipe Network Analysis
Pipe Network Analysis - Solution by loop method - Сообщения
#1 Опубликовано: 14.04.2016 02:36:18
NDTM Amarasekera
NDTM Amarasekera
Examples of a problem solved in SS and Excel are attached.
The results are tallying.
Pipe Network Ex3.1.sm (417,66 КиБ) скачан 1792 раз(а).
Pipe Network by Solver Ex3.xlsx (301,19 КиБ) скачан 1262 раз(а).
Alexander O. Melnik 14.04.2016 14:10:00
#2 Опубликовано: 14.04.2016 03:15:44
Alexander O. Melnik
Alexander O. Melnik
IMHO, in this case the EXCEL solution is "cleaner".
EXCEL shines when you need to process simple formulae applicable to many rows of data... Which we do have in this case.
#3 Опубликовано: 14.04.2016 10:47:43
The problem is not to insist to expand symbolic. If you were scared of that one,
you have seen nothing compared to > 12 pages wide expansion. Before expanding,
hover Unknown(F) and see if it is of any profitable use.
Davide Carpi 14.04.2016 15:22:00
#4 Опубликовано: 14.04.2016 10:49:59
... forgot to attach WS.
Pipe Network.sm (194,18 КиБ) скачан 1574 раз(а).
Davide Carpi 14.04.2016 15:22:00, frapuano 14.04.2016 17:15:00
#5 Опубликовано: 02.05.2016 22:10:30
Gilberto E. Urroz
Gilberto E. Urroz
23 сообщений из 36 понравились пользователям.
Check out Lectures 14b-20 in this website:
http://www.neng.usu.edu/cee/faculty/gurro/Classes/Classes_Spring2013/CEE3510_Spring2013/CEE3510_Schedule.htm
EPANET is the easiest way to solve pipe networks
#6 Опубликовано: 03.05.2016 10:53:06
Ruben Sidranski
Ruben Sidranski
Multiple software to do this. Pipe-flo, AFT Fathom, and others come to mind. If memory serves, the hydraulic institute and a limited node software to do this too.
http://www.pumps.org/Training/Free_Pump_Software.aspx
With that said, I still like to do things on SMath/MathCAD to verify results, since I can "see" the math.
#7 Опубликовано: 03.05.2016 11:32:51
Can't be more right than checking the maths for documenting the project(s).
Elsid, as a byside question: is your Mathcad 15 working ?
My Google web site is still active "mathengjmg". I can see it all, but
since PTC deactivated [scrapped] Mathcad 11 Single User Edition, if I
download any of the 663 work sheets [100MB], none will open.
Would you be kind enough to download some work seets and let me know
if they open in your Mathcad 15 ?
Thanks, Jean
https://sites.google.com/site/mathengjmg[/url]
#8 Опубликовано: 03.05.2016 13:59:56
Ruben Sidranski
Ruben Sidranski
Jean,
I sent private Message
#9 Опубликовано: 03.05.2016 20:09:00
Jean,
Thanks Elsid, I replied.
