Vibrations of membranes
Vibrations of membranes - Messages
#1 Posted: 12/28/2017 5:10:57 PM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Vibrations of a circular membrane.The axisymmetric case
Solution are described with the help of Bessel functions .
https://en.wikipedia.org/wiki/Vibrations_of_a_circular_membrane
Bessel'2.sm (29.66 KiB) downloaded 1317 time(s).
Andrey Ivashov 1/24/2018 4:38:00 PM, Davide Carpi 12/29/2017 12:53:00 PM
#2 Posted: 12/31/2017 1:46:43 PM
Tanks Ber7: saved in your named file.
#3 Posted: 1/6/2018 5:14:01 AM
Fridel Selitsky
Fridel Selitsky
Vibrations of a rectangular membrane
Calculation formulas are taken from the book:S.Timoshenko,
Vibration Problems In Engineering
MemPl.sm (14.03 KiB) downloaded 1262 time(s).
Davide Carpi 1/6/2018 6:21:00 AM, Andrey Ivashov 1/24/2018 4:37:00 PM, frapuano 1/6/2018 8:26:00 AM
#4 Posted: 1/9/2018 6:03:52 PM
Fridel Selitsky
Fridel Selitsky
Vibrations of a circular membrane.The general case
Bessel'5.sm (22.49 KiB) downloaded 1281 time(s).
Andrey Ivashov 1/24/2018 4:37:00 PM, Davide Carpi 1/19/2018 8:26:00 PM
#5 Posted: 1/19/2018 12:37:31 PM
Fridel Selitsky
Fridel Selitsky
Deflection of simply supported equilateral triangular plate
The plate rests on a frame in the form of an equilateral triangle.
The triangular part of the plate is loaded uniformly distributed
load. The equation of the surface of deflections of a triangular plate is taken
from the book of S.P.Timoshenko.Timoshenko S.P., Woinowsky-Krieger S. Theory of plates and shells. New York, NY: McGraw-Hill; 1959.
triangular plate.sm (12.86 KiB) downloaded 1234 time(s).
Andrey Ivashov 1/24/2018 4:37:00 PM, Davide Carpi 1/19/2018 8:26:00 PM, NDTM Amarasekera 1/19/2018 10:43:00 PM
#6 Posted: 1/19/2018 2:47:19 PM
Thanks Ber7 for that one and the other one few days ago.
#7 Posted: 1/24/2018 4:02:51 PM
Fridel Selitsky
Fridel Selitsky
I tried to use the plugin Maxima
PlateMaxima.sm (143.87 KiB) downloaded 1280 time(s).
Andrey Ivashov 1/24/2018 4:37:00 PM, frapuano 1/24/2018 7:43:00 PM
#8 Posted: 1/25/2018 11:52:49 PM
Thanks Ber7, I love those 3D, though it will never beat Mathcad 8... 11.
On my own, I published several times more than the entire Mathcad Community.
I don't miss them in Smath 6179, why ? purely useless for the Engineer.
They are just for the Gallery [Tom G. would say Peanut Gallery].
We are just waiting for a stable Smath version delivered with Maxima plugin
and more of the possible plugins. Scilab looks far superior to Maxima ?
#9 Posted: 1/29/2018 6:24:36 AM
Fridel Selitsky
Fridel Selitsky
Deflection of a Circular Plate.Plate contains rigid
inclusion of radius b and loaded at the Center
(Timoshenko,S.and Woinowsky-Krieger, S.,Theory of plates and shells, 1959)
Inclusion.sm (32.68 KiB) downloaded 1249 time(s).
Davide Carpi 1/29/2018 7:29:00 AM
#10 Posted: 1/26/2019 10:30:30 PM
Laurent Fournier
Laurent Fournier
9 likes in 66 posts.
Hello Beer7, is this vibration of a rectangular membrane equivalent to the deflection of a simply supported, uniformly loaded, rectangular plate? (leaving aside the physical parameters like plate thickness, Young's modulus etc.) I am only interested in the curvature on various locations on the surface, not in absolute values (max deflection can be calculated using simple civil engineering formulaes).
Thanks,
Laurent
#11 Posted: 1/27/2019 12:30:46 AM
Vibrations of a circular membrane.The axis symmetric case
Solutions are described with the help of Bessel functions .
Thanks Ber7, works great. Beautiful work.
mwbesselj(0,x) is ~ 4 times faster 15 decimals
Hart JZERO 5852 is 23 decimals up to ± 8.
Bessel JY.sm (75.19 KiB) downloaded 1199 time(s).
#12 Posted: 1/27/2019 1:55:42 AM
What happened, your previous post is gone with the wind ???
Try this, so much faster !
Bessel mwbesselj Membrane Ber7 [20190126].sm (31.26 KiB) downloaded 1116 time(s).
#13 Posted: 1/3/2021 5:47:58 AM
Fridel Selitsky
Fridel Selitsky
Vibrations of a triangular membrane
Calculation formulas are taken from thearticle:
http://ivdon.ru/uploads/article/pdf/IVD_44__1_Chernyshov.pdf_30f490557a.pdf
Vibration triangular membrane.sm (319.69 KiB) downloaded 1193 time(s).
Alvaro 1/4/2021 12:30:00 PM
#14 Posted: 1/3/2021 11:28:34 AM
Thanks, works fine after doctoring CreateMesh.
#15 Posted: 1/3/2021 1:23:53 PM
Fridel Selitsky
Fridel Selitsky
Vibrations of a triangular membrane(Maxima)
TriangularMembrane Maxima.sm (279.28 KiB) downloaded 1301 time(s).
