1 Pages (6 items)
The problem with the function of the vector - Messages
#1 Posted: 4/7/2020 11:49:26 AM
Please help with the prZadanie 2.sm (9.86 KiB) downloaded 1211 time(s).oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
Thanks for the help
#2 Posted: 4/7/2020 4:16:24 PM
File not found.
WrotePlease help with the prFile not found.oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#3 Posted: 4/7/2020 4:19:22 PM
#4 Posted: 4/7/2020 7:47:33 PM
Hello [userlink]Andrey007[/userlink]
Here there is your code adaped to SS syntax.
To loop the (scalar) functions through the values of a vector (1-column matrix) you can use vectorize or a for/while function.
Since in A=0 Kg(A) is indeterminate (0/0) and Kn(a) is an infinity and you can't plot that I've started the range from the 2nd value within the original range.
Zadanie 2_1.sm (12.66 KiB) downloaded 1215 time(s).
#5 Posted: 4/8/2020 9:29:23 AM
Sorry for some gross mistake ... deleted.
You can use Smath code floor/ceiling
Zadanie 2_1[floor].sm (15.05 KiB) downloaded 1022 time(s).
1 Pages (6 items)
