Double Integration using ode solvers
Double Integration using ode solvers - Messages
#1 Posted: 6/4/2020 1:40:08 AM
1,084 likes in 1,759 posts.
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42.67 KiB) downloaded 1037 time(s).
DoubleIntegralRK.pdf (219.12 KiB) downloaded 657 time(s).
frapuano 6/4/2020 4:03:00 AM, sergio 6/4/2020 4:42:00 AM
#2 Posted: 6/7/2020 1:21:46 PM
SteelCat
SteelCat
3 likes in 47 posts.
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
#3 Posted: 6/7/2020 7:50:25 PM
Can the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6.33 KiB) downloaded 792 time(s).
#4 Posted: 6/17/2020 8:21:22 PM
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60.58 KiB) downloaded 1015 time(s).
GaussLegendreQuadrature.pdf (160.77 KiB) downloaded 586 time(s).
Yes.
DoubleIntegralSteelCat.sm (47.08 KiB) downloaded 976 time(s).
DoubleIntegralSteelCat.pdf (105.49 KiB) downloaded 508 time(s).
sergio 6/18/2020 5:14:00 AM, frapuano 6/18/2020 7:33:00 AM
#5 Posted: 6/18/2020 11:26:19 AM
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28.98 KiB) downloaded 831 time(s).
#6 Posted: 6/18/2020 9:35:42 PM
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25.63 KiB) downloaded 969 time(s).
DoubleIntegralJean.pdf (45.11 KiB) downloaded 573 time(s).
sergio 6/19/2020 5:41:00 AM, frapuano 6/19/2020 9:34:00 AM
#7 Posted: 6/20/2020 7:39:28 AM
Thanks, Amigo !
