Double pendulum model and animation - Is the model correct? - Messages
#1 Posted: 10/29/2025 9:15:19 AM
Hi friends!
Now I am on the forum again!
Anime2.sm (55.59 KiB) downloaded 731 time(s).
But the model is not correct. See please Alvaro model!
Edited 10/30/2025 7:22:14 PM
#4 Posted: 10/29/2025 1:56:31 PM
#6 Posted: 10/29/2025 5:02:10 PM
Слава, а когда этот новая версия плагина появилась?
#7 Posted: 10/29/2025 6:19:29 PM
#8 Posted: 10/30/2025 7:07:54 AM
Hi. My approach to solving the double pendulum problem.
double_pendulum.sm (75.92 KiB) downloaded 781 time(s).
Вячеслав Мезенцев 10/30/2025 9:13:40 AM, sergio 10/30/2025 12:18:26 PM, Valery Ochkov 10/30/2025 7:45:32 AM
#9 Posted: 10/30/2025 1:32:00 PM
#11 Posted: 10/30/2025 7:33:11 PM
Triple pendulum - see errors at the second haft of time interval.
Pendulum-3-for-SMath.xmcd (220.62 KiB) downloaded 808 time(s).
Edited 10/30/2025 7:39:16 PM
Alvaro 10/31/2025 5:05:16 AM
#12 Posted: 10/31/2025 5:03:31 AM
Hi. Using pure SMath code to deduce the equations of motion from the Lagrangian, with the functions in this post: https://smath.com/en-US/forum/topic/AeeMSM/Using-differentials.
double_pendulum_lagrangian.sm (174.64 KiB) downloaded 735 time(s).
double_pendulum_lagrangian.pdf (503.4 KiB) downloaded 580 time(s).
#13 Posted: 10/31/2025 5:10:58 AM
WroteTriple pendulum - see errors at the second haft of time interval.
I no longer use Mathcad, except on rare occasions, when I rely on Mathcad version 11, which I consider the last decent version. So I can't see the triple pendulum file. And I suppose this is the situation for many SMath users who no longer have Mathcad readily available. But more than worrying about the conservation of energy, which seems to be a problem with the numerical method used, I'm more surprised to see how the future affects the past, since the animation shouldn't alter the trajectories already described by the particles as time passes.
This is my approach to the triple pendulum.
triple_pendulum_lagrangian.sm (135.01 KiB) downloaded 732 time(s).
triple_pendulum_lagrangian.pdf (248.09 KiB) downloaded 449 time(s).
Edited 10/31/2025 6:13:23 AM
#14 Posted: 10/31/2025 7:35:30 AM
See pls pdf
Pendulum-3-for-SMath.pdf (589.25 KiB) downloaded 471 time(s).
Edited 10/31/2025 7:38:52 AM
#15 Posted: 10/31/2025 8:37:45 AM
WroteSee pls pdf
With those values:
triple_pendulum_lagrangian.sm (159.26 KiB) downloaded 726 time(s).
Valery Ochkov 10/31/2025 10:39:04 AM
#16 Posted: 10/31/2025 10:38:47 AM
For me too!
#17 Posted: 11/1/2025 1:52:48 AM
#18 Posted: 11/5/2025 7:01:02 AM
Alvaro, hi!
Is it posibble to solve the single pendulun problem with Lagrangian and rkfixed but without the al_nleqsolve function?
Edited 11/5/2025 8:29:15 AM
#19 Posted: 11/6/2025 4:03:01 AM
Hi Valery. For the single pendulum you can get the lagrangian from the olf post about differentials ( https://smath.com/en-US/forum/topic/AeeMSM/Using-differentials ) It's very simple and doesn't require much processing to use rkfixed.
For the double pendulum, you can use Newton-Raphson to solve the system within the function D. Here, a very simple version of the method is used.
double_pendulum_lagrangian-NR.sm (178.15 KiB) downloaded 732 time(s).
Something similar applies to the pendulum with a spring. Note that the Lagrange equations become somewhat complicated because I use the x,y coordinates to calculate the kinetic energy, and SMath cannot simplify trigonometric functions. However, if you use r, θ' (in green), the equations of motion are greatly simplified. But that breaks the principle that the program should do the calculations, not the user.
Valery Ochkov 11/6/2025 5:16:18 AM
#20 Posted: 11/6/2025 11:47:20 AM
WroteHi Valery. For the single pendulum you can get the lagrangian from the olf post about differentials ( https://smath.com/en-US/forum/topic/AeeMSM/Using-differentials ) It's very simple and doesn't require much processing to use rkfixed.
Hi Alvaro!
Can you create this simple sm-file with animation? Single pendulum!
Thanks!
