linfitCheby [Revisit] - linfitCheby [Revisit] - Messages
In this example doing extraordinary well where none else cut the mustard.
Coefficients are transited/isolated via spool to file.
It should create the C:\SmathFile by itself, if not => create it.
Data set from unknown source/application.
Genfit linfitCheby.sm (71.71 KiB) downloaded 998 time(s).
I appreciate very much many of your fitting/interpolation examples. However, if I recall well I think that all of your examples were based on a single independent and a single dependent variable with many unknown parameters. If I was wrong, please excuse me.
On the other hand, I find almost impossible to solve in SMath a nonlinear (based on parameters) fitting problem with a single dependent variable and many independent ones. There are no similar functions like Mathcad mineer(), genfit() or LeastSquaresFit() which will solve the general nonlinear fitting problem with many independent variables.
WroteI appreciate very much many of your fitting/interpolation examples. However, if I recall well I think that all of your examples were based on a single independent and a single dependent variable with many unknown parameters.
Hello Radovan,
I read you well, tough we don't have the Mathcad basis Genfit, the core
component of Minerr, the Smath Genfit fits unknown parameters. Easy or
not easy to fit depends upon the reflexivity of the model function.
Even so, Mathcad can't fit some model functions. The limit in Smath
Genfit is at least 4 or more from recollection.
Actually, there is an immense brew of fitting techniques, it might
turn Vodka with age. Post your example(s) of raw data, will try.
Cheers Radovan ... see you soon ... Jean.
Here is an example posted few times somewhere here in this Forum 6-7 years ago. It is still a univariate fitting problem, but nonlinear in parameters.I think these examples motivated Davide Carpi to make the NonlinearSolvers plugin. You can find there lots of similar discussion (from my side) where I constantly nagged about numerical solvers for nonlinear equations and optimization. There is no plugin solution in SMath yet concerning these problems.
NLMinimization-9c.sm (42.33 KiB) downloaded 941 time(s).
I simply do not know, for years now, how to solve in SMath the general nonlinear fitting problem y=f( X, b ), y - given vector of size n; X - given matrix of size n rows, m columns; b - unknown parameters of size m (m
For example, like this one (also remained unsolved for me in SMath for years)
linfit_multiple-1.sm (22.94 KiB) downloaded 1000 time(s).
linfit_multiple-1-1.sm (22.77 KiB) downloaded 962 time(s).
WroteI simply do not know, for years now, how to solve in SMath the general nonlinear fitting problem y=f( X, b ), y - given vector of size n; X - given matrix of size n rows, m columns; b - unknown parameters of size m (m
Hello Radovan, let me examine your unsolved examples.
In the mean time, these two examples non-linear are educative for new visitors.
1. solves by itself directly from Cholesky LS solver.
2. is hyper robust from the Smath Genfit module [3 iterates]
F.B. Hildebrand wrote "fitting is an art".
Many broke their nose inventing the art of fitting.
The worst is that each case is specific and the fitting techniques is immense.
All in all, Smath did and surely will do all Mathcad 11,
Can't tell more about PTC/Mathcad "cluster fuck"
None of Paul, Robert, Tom exploded the Mathsoft Proprietary Minerr.
Maybe Viacheslav could do, he is a smart cat enough for that.
Genfit NonLinearFit [Revisit].sm (109.66 KiB) downloaded 825 time(s).
I don't know whether this counts as a reasonable fit, but at least you get a solution.
![2019-02-22 18_58_15-SMath Studio 0.99.6988 - [linfit_multiple-1_Kr.sm].png](/en-US/files/Download/h7QzMS/2019-02-22-18_58_15-SMath-Studio-0.99.6988---[linfit_multiple-1_Kr.sm].png)
linfit_multiple-1_Kr.sm (162.77 KiB) downloaded 979 time(s).
Edit: second example shows the same MSE, and nearly the same b2 and b3.
![2019-02-22 19_29_55-SMath Studio 0.99.6988 - [linfit_multiple-1-1.sm_].png](/en-US/files/Download/B8Pzrz/2019-02-22-19_29_55-SMath-Studio-0.99.6988---[linfit_multiple-1-1.sm_].png)
WroteHello Radovan, let me examine your unsolved examples.
... part 1 NLMinimization-9c doctors by itself
... part 2 LM complains ,,, not doctored yet
Thanks for this LM
NLMinimization-9c Scrap.sm (43.34 KiB) downloaded 968 time(s).
Thank you Martin. It was a direct answer to my question - Fit() function from Maxima. Thank you for reminding us of this once more. Fortunately, we have Maxima plugin for nonlinear fitting (it slipped my mind) and I am glad that I was wrong. I also would have liked to be wrong by saying that this is the only function in SMath performing this task (maple plugin maybe?).
WroteI also would have liked to be wrong by saying that this is the only function in SMath performing this task (maple plugin maybe?).
Hi Radovan. In the attached, one of the two maple's fitting functions. Issues at the end.
maple_fit.sm (20.22 KiB) downloaded 933 time(s).
You pointed out some issues with the maple module and using subpackeges.
BTW, could you remind me where can I find the Help for Maple V rev 5. I know I've used it but I forgot where it was.
It will have some smoothing effect on the bivariate,
considering enough data points are in cause.
Not 1/1 Mathcad, but very close.
Maths SlopeIntercept [Medfit].sm (13.71 KiB) downloaded 801 time(s).
