Split Areas(Polygons convex and concave) by lines
Split Areas(Polygons convex and concave) by lines - Momentum curvature by fibers method - Messages
#1 Posted: 7/29/2022 1:13:09 PM
Jesus
Jesus
0 likes in 6 posts.
Hi everyone ,I'm doing a momentum curvature usign Popovic's Method and found a big problem beacuse to divide a polygon(convex and concave) into small fiber like this image but with more lines:
General Polygon
it's not so easy to do an algorithm. I did a smath file when the polygon it's rectangular but for more general case my smath code doesn't work, I'd like know an algorithm, code or function if it's posible in smath or other language to develop.
Jesus.
Verificacion_de_fluencia_en_acero_fiber_method_degradation_forum.pdf (550.67 KiB) downloaded 896 time(s).
#2 Posted: 7/29/2022 4:45:52 PM
If I understand ...
Your polygon has 9 vertices, we can try a circular spline.
That will add as many points between vertices, is it ?
From there: Area, Perimeter, Center of Gravity.
Give the vertices... Jean.
#3 Posted: 7/29/2022 6:10:04 PM
Jesus
Jesus
0 likes in 6 posts.
Hi Jean, exactly I need to known the area, center of gravity and perimeter of the division but the polygon doesn't need to have 9 vertices, this is an example in this case. In general ,I'd like to calculate for n vertices polygon(convex or concave),let me give an example in smath for regular polygon.
polygon_2.sm (36.33 KiB) downloaded 1129 time(s).
Jesus.
#4 Posted: 7/30/2022 3:49:15 PM
Jesus
Jesus
0 likes in 6 posts.
Hi Jean, it was a good solution and you give some ideas to do a code but I'd like to do for more lines and I'd like to optimize the code or algorithm. I did a code in smath maybe need to optimize some parts and get some interesting results, i hope you take a look because a I'd like to aply to convex and no convex polygon, I think it's so hard but I'd like to know the algorithm or code that other programs use. My code doesn't work for some slopes though
Page5 Polygon Copy.sm (116.59 KiB) downloaded 1377 time(s).
Jesus.
#5 Posted: 7/31/2022 7:45:01 AM
1,353 likes in 2,265 posts.
General Polygon
Jesus.
This might be an application for the GPC wrapper plugin by Davide.
gpc1.sm (12.5 KiB) downloaded 1158 time(s).
#6 Posted: 7/31/2022 12:37:52 PM
Jesus
Jesus
0 likes in 6 posts.
Thank you so much, mkraska and Jean, I'll take a look this package (GPC wrapper).
Jesús.
#7 Posted: 7/31/2022 4:06:27 PM
Jesus
Jesus
0 likes in 6 posts.
Ok Jean, I hope You'll find an algorithm to solve that problem.
Jesus
#8 Posted: 8/1/2022 2:09:35 PM
Laurent Fournier
Laurent Fournier
9 likes in 66 posts.
very exciting project!
#9 Posted: 8/1/2022 2:23:17 PM
Jesus
Jesus
0 likes in 6 posts.
Hi Jean it's an excellent solution, thank you so much , I did a code with GPC plugin and I could get this results.
polygon_irregular_fiber_borrador1.sm (34.31 KiB) downloaded 1180 time(s).
polygon_regular_fiber_borrador1.sm (35.48 KiB) downloaded 1160 time(s).
Jesus
#10 Posted: 8/1/2022 3:19:08 PM
... algo style to collapse in utilities.
#11 Posted: 8/1/2022 7:06:15 PM
General hatching procedure for arbitrary contours
gpc2.sm (42.6 KiB) downloaded 1185 time(s).
#12 Posted: 8/2/2022 12:05:56 AM
1,118 likes in 1,794 posts.
Hi. In the attached, a function for see if a point is inside or outside a polygon, and a code for double integrals using Gauss-Legendre coefficients.
InPoly.pdf (97.1 KiB) downloaded 670 time(s).
InPoly.sm (43.3 KiB) downloaded 1141 time(s).
sergio 8/2/2022 11:10:00 AM
#13 Posted: 8/2/2022 2:44:17 AM
Laurent Fournier
Laurent Fournier
Wow!
Will we be able to calculate the static moment and the moment of inertia of any section with these tools?
#14 Posted: 8/2/2022 6:41:33 AM
gpc3.sm (135.5 KiB) downloaded 1242 time(s).
#15 Posted: 8/2/2022 9:21:54 AM
Laurent Fournier
Laurent Fournier
That's superb!
Thanks a lot!
Has anyone worked on polyhedra, convex hulls and polar polyhedra?
#16 Posted: 8/2/2022 11:16:59 AM
... refreshed for convenience.
Maths Polygon Create.sm (99.71 KiB) downloaded 1158 time(s).
#17 Posted: 8/2/2022 12:35:53 PM
I may have something on convex hull
Polyhedra, we have C_60 extracted from the adjacency matrix.
#18 Posted: 8/2/2022 1:41:40 PM
Laurent Fournier
Laurent Fournier
anything on the adjacency matrix I am super interested!
Handling the adjacency matrix is the only difficulty in fact. Polarity of points-planes is easy.
#19 Posted: 8/2/2022 8:47:43 PM
1. In the attached Buckyball, adjacency matrix is from Mathsoft,
Mathsoft borrowed fro Matlab.
2. I have the Mathcad convex hull ORIGIN 0
RemToDo ORIGIN 1 for Smath coding.
Buckyball Adjacency.sm (16.36 KiB) downloaded 1121 time(s).
0Anim Buckyball.sm (107.29 KiB) downloaded 1128 time(s).
Buckyball.sm (176.41 KiB) downloaded 1173 time(s).
Laurent Fournier 8/2/2022 11:36:00 PM
#20 Posted: 5/24/2023 5:25:09 PM
CLEISON ARMANDO MANRIQUE AGUIRRE
0 likes in 2 posts.
I guess we can not use the same matrix of contour point to get the area and de center of mass ... Or am I wrong ?
