1 Pages (7 items)
symbolic vs numeric optimisation - Ioan - Messages
#1 Posted: 9/16/2012 4:32:13 PM
#2 Posted: 9/17/2012 11:34:42 AM
Hello
The function norme(v) is buggy (known issue in the forum). Use [MATH]sqrt(v^2)[/MATH] instead if v is a single column as in your example. Works with both numeric and symbolic optimization.
Best regards, Martin Kraska
#3 Posted: 9/17/2012 1:18:38 PM
Hello Martin,
Thanks for your answer.
I replaced all norme(v) as you suggest (see attached file) and for case of symbolic optimisation the results are still wrongs (?).
Best regards,
Ioan
rotsys2.sm (27.08 KiB) downloaded 1148 time(s).
Best regards,
Ioan
#4 Posted: 9/17/2012 7:29:32 PM
Hello Ioan,
ok, you are right. Replacing enorm is not sufficient to solve the problem. There is another one with trig operations. The problem is that [MATH]sin(θ)[/MATH] is symbolically evaluated to zero, whereas the correct value is [MATH]sqrt(2)/sqrt(3)[/MATH]. If you ask SMath to simplify [MATH]sin(acos(a))[/MATH] you get [MATH]sin(acos(a))=sqrt(1-a^2)[/MATH]. If you use that instead of [MATH]sin(θ)[/MATH] :
[MATH lang=ENG]R
then you get the correct symbolic result.
[MATH lang=ENG]R=mat(-{1-sqrt(3)}/{2*sqrt(3)},{1+sqrt(3)}/{2*sqrt(3)},1/sqrt(3),{1+sqrt(3)}/{2*sqrt(3)},-{1-sqrt(3)}/{2*sqrt(3)},-1/sqrt(3),-1/sqrt(3),1/sqrt(3),-1/sqrt(3),3,3)[/MATH]
Symbolic evaluation seems to be not really reliable. Simplifications are not done even if SMath is well aware of that they could be done.
An example is
[MATH lang=ENG]cos(θ)={mat(0,0,-1,3,1)*mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)}/{sqrt(mat(0,0,-1,3,1)^2)*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)}[/MATH]
which is not simplified although the following works:
[MATH lang=ENG]{mat(0,0,-1,3,1)*mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)}/{sqrt(mat(0,0,-1,3,1)^2)*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)}=-1/sqrt(3)[/MATH]
Also, if [MATH]sin(acos(a))=sqrt(1-a^2)[/MATH] then the following cannot be correct:
[MATH lang=ENG]sin(θ)=sqrt({sqrt(mat(0,0,-1,3,1)^2)^2*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)^2-1}/{sqrt(mat(0,0,-1,3,1)^2)^2*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)^2})[/MATH]
Here, perhaps the symbolic engine tries to apply the square to the dot product by applying the square to the factors individually. This yields 1 because both vectors are unit vectors. It might be correct for scalars but definitely not for vectors. BTW it does not help to use matrix formulation of the dot product [MATH lang=ENG]el(transpose(v)*v,1)[/MATH]. We had such issues already with SMath assuming matrix multiplication to be commutative.
By the way, instead of your special function you could write [MATH lang=ENG]v.i†v.f=mat(1/sqrt(3),1/sqrt(3),0,3,1)[/MATH].
#5 Posted: 9/18/2012 2:29:56 AM
Hello Martin,
Thanks a lot for your useful analysis.
Best regards,
Ioan
Best regards,
Ioan
#6 Posted: 10/20/2012 5:27:08 AM
here is one more example for incomplete symbolic simplification in trig context. SMath knows that sin(30° ) equals 1/2 but can't find out symbolically that cosec(30° )=1/sin(30° ) is 2.
trig.sm (9.29 KiB) downloaded 1137 time(s).
#7 Posted: 10/22/2012 1:42:00 AM
WroteHi,
Wow, so difficult to me
1 Pages (7 items)
