symbolic vs numeric optimisation
symbolic vs numeric optimisation - Ioan - Сообщения
#1 Опубликовано: 16.09.2012 16:32:13
Ioan
Ioan
1 сообщений из 26 понравились пользователям.
Hi Andrey,
Here attached I have an other case where the symbolic optimisation gives a completely false results.
Hoping to serve for yours futures improvements.
Best regards,
Ioan
rotsys.sm (22,78 КиБ) скачан 1407 раз(а).
#2 Опубликовано: 17.09.2012 11:34:42
Hello
The function norme(v) is buggy (known issue in the forum). Use [MATH]sqrt(v^2)[/MATH] instead if v is a single column as in your example. Works with both numeric and symbolic optimization.
Best regards, Martin Kraska
#3 Опубликовано: 17.09.2012 13:18:38
Ioan
Ioan
Hello Martin,
Thanks for your answer.
I replaced all norme(v) as you suggest (see attached file) and for case of symbolic optimisation the results are still wrongs (?).
Best regards,
Ioan
rotsys2.sm (27,08 КиБ) скачан 1376 раз(а).
#4 Опубликовано: 17.09.2012 19:29:32
Hello Ioan,
ok, you are right. Replacing enorm is not sufficient to solve the problem. There is another one with trig operations. The problem is that [MATH]sin(θ)[/MATH] is symbolically evaluated to zero, whereas the correct value is [MATH]sqrt(2)/sqrt(3)[/MATH]. If you ask SMath to simplify [MATH]sin(acos(a))[/MATH] you get [MATH]sin(acos(a))=sqrt(1-a^2)[/MATH]. If you use that instead of [MATH]sin(θ)[/MATH] :
[MATH lang=ENG]Ridentity(3)+sqrt(1-({v.f*v.i}/{sqrt(v.f^2)*sqrt(v.i^2)})^2)*mat(0,-el(p,3),el(p,2),el(p,3),0,-el(p,1),-el(p,2),el(p,1),0,3,3)+(1-cos(θ))*(p*transpose(p)-identity(3)))[/MATH]
then you get the correct symbolic result.
[MATH lang=ENG]R=mat(-{1-sqrt(3)}/{2*sqrt(3)},{1+sqrt(3)}/{2*sqrt(3)},1/sqrt(3),{1+sqrt(3)}/{2*sqrt(3)},-{1-sqrt(3)}/{2*sqrt(3)},-1/sqrt(3),-1/sqrt(3),1/sqrt(3),-1/sqrt(3),3,3)[/MATH]
Symbolic evaluation seems to be not really reliable. Simplifications are not done even if SMath is well aware of that they could be done.
An example is
[MATH lang=ENG]cos(θ)={mat(0,0,-1,3,1)*mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)}/{sqrt(mat(0,0,-1,3,1)^2)*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)}[/MATH]
which is not simplified although the following works:
[MATH lang=ENG]{mat(0,0,-1,3,1)*mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)}/{sqrt(mat(0,0,-1,3,1)^2)*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)}=-1/sqrt(3)[/MATH]
Also, if [MATH]sin(acos(a))=sqrt(1-a^2)[/MATH] then the following cannot be correct:
[MATH lang=ENG]sin(θ)=sqrt({sqrt(mat(0,0,-1,3,1)^2)^2*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)^2-1}/{sqrt(mat(0,0,-1,3,1)^2)^2*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)^2})[/MATH]
Here, perhaps the symbolic engine tries to apply the square to the dot product by applying the square to the factors individually. This yields 1 because both vectors are unit vectors. It might be correct for scalars but definitely not for vectors. BTW it does not help to use matrix formulation of the dot product [MATH lang=ENG]el(transpose(v)*v,1)[/MATH]. We had such issues already with SMath assuming matrix multiplication to be commutative.
By the way, instead of your special function you could write [MATH lang=ENG]v.i†v.f=mat(1/sqrt(3),1/sqrt(3),0,3,1)[/MATH].
#5 Опубликовано: 18.09.2012 02:29:56
Ioan
Ioan
Hello Martin,
Thanks a lot for your useful analysis.
Best regards,
Ioan
#6 Опубликовано: 20.10.2012 05:27:08
here is one more example for incomplete symbolic simplification in trig context. SMath knows that sin(30° ) equals 1/2 but can't find out symbolically that cosec(30° )=1/sin(30° ) is 2.
trig.sm (9,29 КиБ) скачан 1377 раз(а).
#7 Опубликовано: 22.10.2012 01:42:00
Geraldinehenry
Geraldinehenry
Wow, so difficult to me
