calculation in table
calculation in table - Messages
#1 Posted: 11/14/2017 12:39:44 PM
Paulius
Paulius
0 likes in 11 posts.
Is possible to make calculation in table, like excel?
#2 Posted: 11/14/2017 4:34:30 PM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
Not that I am aware off, but you can "connect" to EXCEL if you have it on your windows machine:
https://en.smath.info/forum/yaf_postst4375_Plugin---EXCEL--2003--I-O-with-recalculation-and-export-to-PNG.aspx
#3 Posted: 11/14/2017 8:09:50 PM
Your question is too vague, a bit of work sheet would help.
In short: there is no known limit about what Smath can do
within a matrix [its own matrix] wrt the project you are Engineering.
Then, you may send to Excel via Alex plugin.
Alex, please correct me if wrong !
Cheers.
#4 Posted: 11/15/2017 4:54:27 AM
Peter J Francis
Peter J Francis
0 likes in 18 posts.
Hi Paulius,
I had a similar problem.
I wanted to create a table of values for a project at work that could be easily read by non SMath people (i.e. I wanted a nice looking table but also array names with text to identify the value rather than numbers)
Some of the values were fixed (sizes , powers or text ) but I needed to perform calculations on some of the values and incorporate it in a table.
I came up with the following method using TableRegions , although it looks a little complicated it works great and generates a great looking table and I can use arrays with meaning full text identifiers.
The attached file is annotated so should be fairly self explainatory and there are some examples of how to use the values at the bottom.
If you have a problems with it let me know.
TableRegion example by PJF.sm (30.69 KiB) downloaded 1293 time(s).
Peter
Peter J Francis Twitter: @PeterJFrancis Thermal Engineer , Maker , Pilot
#5 Posted: 11/15/2017 9:26:33 AM
Paulius
Paulius
Tnank You Peter
#6 Posted: 11/15/2017 11:49:34 AM
Thanks Peter: gorgeous ! mm² ... mm[Alt+253]
Hi Paulis ... here is some bed time reading
Rotate Eol.sm (28.47 KiB) downloaded 1161 time(s).
Utilities Matrix Truth Table.sm (59.2 KiB) downloaded 1083 time(s).
0Anim Brownian.sm (9.94 KiB) downloaded 1065 time(s).
2D Fill Stem.sm (12.71 KiB) downloaded 1069 time(s).
0Anim Ellipse.sm (13.85 KiB) downloaded 1079 time(s).
0Anim Analemma.sm (29.24 KiB) downloaded 1107 time(s).
Inst_Colebrook Pipe Data.sm (60.09 KiB) downloaded 1124 time(s).
2D Isometric Copy.sm (77.29 KiB) downloaded 1031 time(s).
Utilities Matrix Treasury Copy.sm (355.68 KiB) downloaded 1068 time(s).
Rotate Image RGB.sm (348.52 KiB) downloaded 1099 time(s).
Rotate Breather [4 Orientations].sm (1000.05 KiB) downloaded 905 time(s).
Image ZOOM Cosmos RGB.sm (1.79 MiB) downloaded 1081 time(s).
Peter J Francis 11/15/2017 1:02:00 PM, frapuano 11/15/2017 4:58:00 PM
#7 Posted: 11/16/2017 2:06:31 AM
Alexander O. Melnik
Alexander O. Melnik
Cheers.
Agree with Jean - you can do all sorts of operations in SMath with matricies and then present them as a table region OR you could use excel to do an present all the table stuff for you.
