1 Pages (7 items)
LM Algorithm - LM Algorithm - Messages
#1 Posted: 9/16/2018 6:14:14 PM
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Levenberg_Marquardt_Code_CBG Copy.sm (65.28 KiB) downloaded 1111 time(s).
Andrey Ivashov 9/26/2018 6:15:00 PM
#2 Posted: 9/18/2018 5:24:56 PM
Hello Jean,
The same example of the Levenberg Marquardt Algorithm, but obtaining
the Jacobian Matrix through finite differences
Levenberg_Marquardt_Code_CBG_Jean_JMFD.sm (77.37 KiB) downloaded 1093 time(s).
Carlos
Carlos
#3 Posted: 9/20/2018 11:23:37 AM
WroteHello Jean,
Thanks, Carlos: works fine.
More doctoring for you !
The work sheet "Otherwise" is only slightly otherwise for convenience, works fine.
The "Jacobian Fails" is another model attempted, Jacobian complains ... Ah !
Same model Pharmacokinetics works fine Conjugate gradient Minimize.
True: some model function can only be fitted by hand
True: GenfitMinimze may be difficult to initialize but work fine for my huge
collection [about 80 projects in Smath].
Levenberg_Marquardt_Code_CBG Model Otherwise Jacobian FAILS.sm (35.77 KiB) downloaded 1107 time(s).
Genfit Pharmacokinetics.sm (43.67 KiB) downloaded 1060 time(s).
Levenberg_Marquardt_Code_CBG Model Otherwise.sm (53.53 KiB) downloaded 1118 time(s).
#4 Posted: 9/20/2018 12:04:20 PM
WroteMore doctoring for you !
Jacobian is rescued but does not finish solving
... God does not love Jacob anymore !
Levenberg_Marquardt_Code_CBG Model Otherwise Jacobian NOT calc.sm (39.62 KiB) downloaded 1094 time(s).
#5 Posted: 9/20/2018 11:24:19 PM
Hello Jean
Here is the L-M file that works with your example.
Levenberg_Marquardt_JMFD_CBG.sm (53.29 KiB) downloaded 1073 time(s).
Carlos
Carlos
#6 Posted: 9/21/2018 4:50:22 PM
WroteHello Jean
Thanks Carlos for doctoring.
By some regrouping, timing dropped from 3.8 min down to 2.6 min.
Niece Smath document for classroom and publishing.
Genfit Pharmacokinetics L-M Copy.sm (60.57 KiB) downloaded 1003 time(s).
#7 Posted: 9/26/2018 6:03:04 PM
Hi Jean
Another example of the application of the Levenberg Marquardt algorithm,
this time with the Tesla function.
Levenberg_Marquard_Tesla_OK_CBG.sm (546.62 KiB) downloaded 1126 time(s).
Carlos
Carlos
1 Pages (7 items)
