question of roots
question of roots - Messages
#1 Posted: 8/31/2023 3:43:11 PM
Prmtv
Prmtv
0 likes in 49 posts.
Hello. I can't understand. Why does it turn out 4 roots or not 2? Thanks.
#2 Posted: 9/1/2023 1:10:52 AM
1,083 likes in 1,756 posts.
Hi. Because that's how what might be called "scalar expansion" for sys() works. Perhaps the result you are looking for is this using vectorize()
sergio 9/1/2023 4:49:00 AM
#3 Posted: 9/1/2023 1:43:31 PM
Prmtv
Prmtv
Thanks!
How it is better to set then an array of the data? Need to get a solution for some data (for example: values a 4, 5, 6, 7...)
Matrix didn't work either.
#4 Posted: 9/2/2023 3:07:12 PM
Hi. Supposedly, vectorize operates only on matrices.
Need to get a solution for some data (for example: values a 4, 5, 6, 7...) Matrix didn't work either.
It should have worked. Do you have an example of how it didn't work?
#5 Posted: 9/2/2023 6:51:05 PM
Visit the Samples ... find zillions of examples.
#6 Posted: 9/2/2023 8:35:19 PM
591 likes in 1,369 posts.
You can use range() functions.
