1 Pages (7 items)
Strange results - Messages
I've been using SMath (0.89) for about a year now and never experience this. Its why I alway put the result next to the equation to be sure I'm getting a reasonable result. The value of Wdsw is 10^31 when it should have been only 757. If I set optimization as Numeric I get the correct result. More reason to keep a check on running results. If I hadn't who knows what the final result would be.
Ed
Hello Ed,
This is one more example among others where the "Symbolic" optimization had problems with. I tried to reproduce it and the value of W.dsw is somewhat different than in your case.
[LIVE width=461 height=588]http://smath.info/live/?file=2711[/LIVE]
Here - "None" or "Numeric" will give the correct numerical value.
Someone on this Forum suggested having the option to set "None" or "Numeric" as default instead of "Symbolic". optimization. I suppose that this might be one of the possibility, until the fixing of this problem.
atan(0.5) = 1.5359 according to SMath Studio... I beg to differ
angle units set to degrees
using version 0.89 (build 3856)
This was a known issue and corrected in 0.89.9. There is no "Angle units" option anymore
radians - no units or unit "rad"
degrees - units "deg" or "°"
[LIVE width=226 height=60]http://smath.info/live/?file=2754[/LIVE]
Strange?? Live version gives wrong result here. The 0.89.8 version gives the correct result
atan(0.5)=26.5651@'deg
EDIT: I messed up with "grad" and "deg", sorry
Hello Radovan,
I think, SMath live calculates correct.
But the result unit is grad, not degree (400grad = 400gon = 360degree).
Best Regards,
Peter
Best Regards,
Peter
Wrote...But the result unit is grad, not degree (400grad = 400gon = 360degree).
Thank you Peter, you are right.
Sorry, my mistake - I messed up "grad" and "deg"
Hello Radovan,
in my opinion the unit 1grad = 1gon in SMath leads to mistakes, because grad is
normally used as alternative for deg.
To avoid confusion and mistakes I recommend to delete the unit grad from the unit-list in SMath or redefine it.
Btw., in MathCad: 1Grad = 1deg
Best Regards,
Peter
Best Regards,
Peter
Radovan Omorjan 2011/5/19 02:18:00
1 Pages (7 items)
