Procedural variables
Procedural variables - Messages
#1 Posted: 2023/7/6 23:12:48
Lupus the Canine
Lupus the Canine
0 likes in 7 posts.
Is it possible to procedurally define variables from strings?
I want to load data to a lot of sets of variables with names following a pattern preferably without doing that manually.
Is there a better way than:
example.sm (4.39 KiB) downloaded 1253 time(s).?
#2 Posted: 2023/7/7 05:06:15
1,443 likes in 2,935 posts.
That's one of the other options.
#3 Posted: 2023/7/7 16:18:37
Lupus the Canine
Lupus the Canine
0 likes in 7 posts.
Thanks, unfortunately value to be assigned is supposed to come from somewhere else, z was just an example because I didn't want to make example with large vectors or matrices to be assigned.
I was looking for a function that would turn a string into a variable that can be used as lhs operand in assignment.
#4 Posted: 2023/7/7 20:02:53
1,355 likes in 2,271 posts.
If the value to be assigned is an ordinary expression, then just convert it to a string before using the above-mentioned methods.
asg.sm (4.31 KiB) downloaded 1278 time(s).
#5 Posted: 2023/7/7 23:52:52
598 likes in 1,380 posts.
Something like this?
z can be anything and come from anywhere.
As long as it has same length with v.
StrAssign.sm (6.91 KiB) downloaded 1229 time(s).
Click to enlarge
#6 Posted: 2023/7/8 17:48:00
Lupus the Canine
Lupus the Canine
0 likes in 7 posts.
Thank you for your help makraska and overlord.
This look great. I will throw eval in there to be sure it is numeric assignment.
#7 Posted: 2023/7/10 09:53:28
Thanks, unfortunately value to be assigned is supposed to come from somewhere else ...
I was looking for a function that would turn a string into a variable that can be used as operand in assignment.
algo(col) will deal with mixed import matrix.
You can code to convert mixed or numeric or string.
Select the desired matrix-col.
Subsequently, set your maths.
The attached document SS 6179, I checked it opens 30405.
Please, confirm it opens on your system.
Maths Convert-str2num COL algo.sm (5.74 KiB) downloaded 1271 time(s).
