solve 2 equations with 2 variables
solve 2 equations with 2 variables - solve 2 equations with 2 variables - Messages
#1 Posted: 2017/8/23 04:25:38
Sjoerd
Sjoerd
0 likes in 7 posts.
what is the best way to solve 2 equations with 2 variables?
example:
(Fa*2)+(Fb*10)+20=0
(Fa*3)+(Fb*9)+15=0
What is the easiest way to solve the 2 equations with 2 variables ?
What function can I use best to find the values of Fa & Fb?
Sjoerd
#2 Posted: 2017/8/23 07:15:13
There are more ways exemplified in the attached Smath.
Setup the system in traditional format, the solving
algebra follows ... Universal. Same approach will
optimize a data set for polynomial best fit.
Cheers, Jean
Solve [x,y,z] Compactum.sm (91.88 KiB) downloaded 901 time(s).
Davide Carpi 2017/8/23 07:19:00
#3 Posted: 2017/8/23 07:31:09
1,355 likes in 2,271 posts.
The Solve function from the Maxima Plugin finds symbolic solutions, equations can be non-linear and involve units.
The attached file is taken from the interactive handbook (available in the extension manager).
_Solve.sm (35.8 KiB) downloaded 1273 time(s).
#4 Posted: 2017/8/23 11:07:04
What function can I use best solve
Implict solver works in the stable Smath 6179.
#5 Posted: 2017/8/23 18:32:45
Sjoerd
Sjoerd
0 likes in 7 posts.
Many Thanks for the help sofar. I downloaded v14 + maxima en try to use the solve function, but I got the message as displayed in the enclosed file:no object reference.JPG
Translation of Dutch message: The reference of the object is not adjusted to an item of the object
What can be the problem ?
Another question: the solve option under the Calculation tab is grayed out. It seems I can not use this solve option. What can be the point ??
regards,
Sjoerd
#6 Posted: 2017/8/23 19:34:02
What is v14? I recommend to use the latest nightly build of SMath and Maxima, see http://en.smath.info/forum/yaf_postsm11095_Maxima-Plugin.aspx#post11095.
#7 Posted: 2017/8/24 16:53:03
Sjoerd
Sjoerd
0 likes in 7 posts.
I use version 14 as is visible in :
I use windows 10 . Can that be the problem.
Do I have to do some installation settings to get maxima running ?
I tested the solve.sm file, when I recalculate the page. Maxima starts up but keeps on calculating for a very very long time, without a solution!
Maxima reagiert nicht!
what can be the problem??
regards,
Sjoerd
#8 Posted: 2017/8/24 17:58:24
I can only handle problems with SMath 0.98.6398 and newer (nightly builds), at least if related to the Maxima plugin.
With this new version the configuration of the Maxima plugin is easy (I streamlined the settings dialog and fixed several bugs).
Just follow the instructions on http://en.smath.info/forum/yaf_postst2078_Maxima-Plugin.aspx. There have been reports of successful installation under Win10, however, I rund Win7 and thus rely on third party reports. Let me know if there are problems and also if everything goes well.
#9 Posted: 2017/8/25 08:37:48
None of the solving approach is correct.
0.5 sec visit 6179 to solve the patients.
Too big to make an image.
Solve System High accuracy.sm (115.73 KiB) downloaded 1107 time(s).
#10 Posted: 2017/8/25 08:55:59
... if it looks innocent to solve by hand, not so !
#11 Posted: 2017/8/25 12:23:23
... rather, download this one. Last module fails after saving.
Very annoying that it works during construction but not after.
Solve System High accuracy.sm (116.5 KiB) downloaded 1103 time(s).
#12 Posted: 2017/8/25 16:07:45
Sjoerd
Sjoerd
0 likes in 7 posts.
In two versions I downloaded and try to run , the following message appears:
The versions I downloaded are:
The strange thing is that my Windows Defender software is already disabled !!?
In this way I am not able to start Smath at all !
#13 Posted: 2017/8/25 17:05:10
The only change I did to the executable was to set the 32 bit flag which is required for the Mathcad user library interface to work (Steamtables and Special math functions libs, userefi plugin). If you don't need this, then replace the executable in the portable distribution by the one in the LINUX version (yes, even if you are under win).
If that doesn't work you can still try the installation procedure described in http://en.smath.info/forum/yaf_postst2078_Maxima-Plugin.aspx. This exclusively uses original installers.
#14 Posted: 2017/8/25 17:08:19
Do you mean: you couldn't download none of the
work sheet I attached ? Strange Smath does not
start. Try to call from the icon in the Smath
main directory.
