1 Pages (7 items)
Problem with integral (again) - Definite Integral - Messages
Hi!
I have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem?
Thanks a lot!
Bye
Pali
HF.sm (72.86 KiB) downloaded 1127 time(s).
Thanks a lot!
Bye
Pali
WroteI have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem ?
In some way doctored in red. Setup the integrator scalar wrt 'x'.
HF.sm (84.02 KiB) downloaded 1120 time(s).
Hi Pali. At this time, you can't use if(..) inside an integral, use cases(...) instead. Also, SMath's integral new version can handle better units.
HF.sm (73.15 KiB) downloaded 1129 time(s).
Hi Alvaro,
thanks a lot! It works fine. Thank you.
What do you mean: new version of integral?
Pali
Pali
I do not really understand what you did, but thanks for your help as well.
1. recast if/else ► if/otherwise.
2. made ∫ scalar wrt 'x' for local/vectorize
HFshort.sm (23.97 KiB) downloaded 1076 time(s).
Hi Pali. In the "new" version of the integral it puts the units of the result correctly, while before some corrections had to be made. From "list of changes" here: Defined Integral supports units now.
Davide Carpi 2022/12/16 18:26:00
1 Pages (7 items)
