Matrix element
Matrix element - Calculating with arrays - Messages
#1 Posted: 2013/11/19 13:15:38
Henrique
Henrique
1 likes in 17 posts.
Why it doesn't work on SMath ? It works fine on MathCAD 14.
Matrix element
#2 Posted: 2013/11/19 17:49:17
IVR
IVR
3 likes in 15 posts.
1. Read program's documentation
2. Use for loop
#3 Posted: 2013/11/20 07:16:34
mb10
mb10
9 likes in 20 posts.
#4 Posted: 2013/11/20 07:22:20
Henrique
Henrique
I didn't find anything about calculating with arrays in this way. And it's not necessary to use loop as i won't test anything. In addition to typical linear algebra calculations, arrays in Mathcad are useful for performing calculations repeatedly over a range of values. See in the first image another SMath example and in the 2nd image how Mathcad does it:
#5 Posted: 2013/11/20 12:03:09
1,308 likes in 2,221 posts.
SMath cannot handle vector-valued indices in expressions (AKA "range variables" in Mathcad). Therefore you MUST use loops or you rely on functions from 3rd party plugins like matlab c++ library by uni or Maxima, where nearly all functions can be applied to vectors (without indices). Your example reveals that you might not be aware of the difference between text indices and adress- or array indices.
Most of the tutorials for SMath adress this issue, as this is a very common pitfall for newbies.
Section matrix elementwise.sm (35.55 KiB) downloaded 908 time(s).
#6 Posted: 2013/11/21 12:13:51
Henrique
Henrique
My intention was to reproduce in SMath Studio operations with vectors as in Mathcad. I understand you, but on Mathcad there is no problem to do like that. Besides, only now I'm working with SMath, and I also learning on how to use the program.
