custom regions
custom regions - Messages
#1 Posted: 2012/1/9 18:38:56
kilele
kilele
134 likes in 397 posts.
I'm intrigued about the new feature "custom regions" included in 0.90 version. Any hint on what it is about?
BTW, how can i donate using paypal? I already donated this way but cant see this option right now.
#2 Posted: 2012/1/10 04:48:24
2,340 likes in 4,041 posts.
Hello. You can find the Custom Region example in the opened SVN repository here: https://smath.info/svn/public/plugins/CheckBoxRegion/.
Just build the project and put the resulting DLL to "plugins" folder of SMath Studio - you will see a new Region to insert via Menu > Insert.
Regards.
#3 Posted: 2012/1/10 10:57:22
kilele
kilele
Regards.
Sorry, I'm not in programming with visualStudio yet.
Is this a new kind of region apart from "Area" introduced in 0.89.8 Beta?
Is an alternative way to program plugins without visualStudio?
Thanks
#4 Posted: 2012/1/11 05:31:59
Yes, this is something apart from Area.
I've prepared some files for you to play with it:
  1. Download Checkbox Plugin and put it to plugins folder of the installation directory of SMath Studio.
  2. Run SMath Studio and find the Checkbox item in the Insert menu.
  3. Download and open the example .sm file for quick start.
Visual Studio is the easiest way to create plugins.
Regards.
#5 Posted: 2012/1/11 22:30:30
Edward Ulle
Edward Ulle
21 likes in 182 posts.
Andrey,
The ability to add controls is an exciting addtion to SMath . I downloaded the Check Box but haven't figured how to use the control. Clicking it turns it from solid filled to empty filled but how do I associate with some value. I'll play with it this weekend. I'm thinking this will open up greater access to the SMath Desktop for other controls .
Ed
#6 Posted: 2012/1/12 04:31:11
Variable "checked" is hard-coded for this component for now (I will improve this plugin later). So, clicking on it will change value of this "checked" field from "0" to "1" and vise versa. I've shown it in the attached to my previous comment example.
Regards.
