1 Pages (9 items)
[SS-2302] Smath File Crash - Messages
The following Smath File worked fine under 97.5890. It opens a Excel data file for analysis.
But it crashes under 98.5905.
Why this happens?
Why this happens?
The crash is triggered in sum(1)
Even copying the Q matrix in a definition on the canvas the crash still happens.
Issue isolated: crash sum 1.sm (318.57 KiB) downloaded 1153 time(s).
P.S. try sum(identity(30)) and sum(identity(50)), the second one crashes for me
opened as issue SS-2302
WroteP.S. try sum(identity(30)) and sum(identity(50)), the second one crashes for me
The second one crashes for me too
Davide Carpi 2016/3/5 13:38:00
Good catch! Fixed (see http://en.smath.info/forum/yaf_postst7329_UPDATED--SMath-Studio-0-98-5908--05-March-2016.aspx).
Regards.
Regards.
Ioan,
You can dedicate a function "VectorMatrixSum(data)"
Unwrap has many more applications, thus interesting.
Under the hood, your combined Sigmas, they first
Unwrap. Matrices don't exist in computing Machinery.
Matrices exist as serialised components.
The "BombCompute Mathcad 11", copy/paste a fair size
matrix [16000000 per say] takes substantial time.
"Warning: the requested operation may take long time".
Can't be more true.
Cppy/paste 16000000 vector: NO warning message... done.
Chers, Jean
Can't be more true.
Chers, Jean
Thank you Andrey.
The problem on Smath file crash is now solved.
Andrey Ivashov 2016/3/6 17:37:00
WroteThank you Andrey.
"now solved", maybe not so wrt matrix manipulation.
Observe the matrix scale code: M-Min(M)
I found out this built-in code is weak, prone to failure
with incorrect error message " Matrix is not invertible".
There is no matrix inversion involved. Observe the robust
code doing same. Example has low numerical values. At values
in the order of 10^10, module [1] fails.
Utilities Matrix Scale.sm (14.19 KiB) downloaded 1118 time(s).
Davide Carpi 2016/3/7 09:19:00
1 Pages (9 items)
