Function as variable for another function
Function as variable for another function - Is it possible to use function as variable for function if in this functon is if statement.. - Messages
#1 Posted: 2020/9/27 17:24:11
Rihards
Rihards
0 likes in 2 posts.
function doesnt work if in argument function there is if
is it possible to add function as argument to another function if in that function is if statement?
#2 Posted: 2020/9/27 17:41:02
1,123 likes in 1,795 posts.
I guess that you have an unit issue, instead to ask "x=1" try with "x=1*'m".
#3 Posted: 2020/9/27 17:51:46
Rihards
Rihards
0 likes in 2 posts.
Quote
no i tried with out any units.. as far as i can tell its if there is if in the function i cant use it as argument for another function even if it plots perfect as i imagine..111fff.PNG
so i played around even further:
it seems that: i can make boolean operations with x and i can use if if x is not evaluated.. but if in if statement there is x then it shows that x is not defined.? is this bug?
#4 Posted: 2020/9/27 19:46:38
This is an "if-issue". It can't be integrate, nor derivate (sometimes) and also can't be called in this way. As workaround use cases.
#5 Posted: 2020/9/27 20:45:03
If you have no plot => you have no project.
#6 Posted: 2020/9/27 21:07:15
Smath Bible is largely in Samples
Integrate Discontinuous_1.sm (24.52 KiB) downloaded 1001 time(s).
#7 Posted: 2020/9/27 21:17:25
Integral 0Discrete Cumulative 10 styles.sm (179.98 KiB) downloaded 985 time(s).
