SMath Studio on Linux
SMath Studio on Linux - Messages
#1 Posted: 2023/2/8 19:55:53
Oichi
Oichi
4 likes in 35 posts.
I downloaded SMath Studio AppImage from the website on ubuntu 22.04. Whenever I open it, it loads that green loading box attached below then it crashes. Any help please?. Thanks in advance
#2 Posted: 2023/2/9 08:28:22
580 likes in 1,348 posts.
Try to run with sudo.
Whether appimage or regular, it won't run without sudo.
Well it will, but you must try a lot of times to make it run.
A link to a thread for further examination
This is a mono bug specific to debian distros except for one.
It is related with glibc and kernel version I suppose.
As far as I know due to my experience, only Debian based
distro I could run SMath without sudo is MXLinux (ahs).
If SMath doesn't run even, please run it under a terminal.
And post terminal output here, maybe it is a faulty plugin.
#3 Posted: 2023/12/12 18:51:26
mocarny_knur
mocarny_knur
0 likes in 1 posts.
I created account on this forum only to write that if You install in Ubuntu 22.04:
libmono-cil-dev
libmono-db2-1.0-cil
mono-dbg
mono-devel
mono-tools-devel
then it should work without sudo. This is some bug within mono and installing mono debugging allows it to run apparently.
#4 Posted: 2024/9/15 02:33:00
usamakhan
usamakhan
3 likes in 75 posts.
I am running SMath on my OrangePi-3b arm64 so far so good. Can anyone tell me how to use GTK themes for mono applications. SMath looks ugly
#5 Posted: 2024/9/16 00:49:21
Especially if your theme is dark for linux, SMath becomes unusable.
Buttons can't be seen, toolbars are too dark, etc.
So I edit smathstudio_desktop_mono file as below.
#!/bin/sh
HERE="$(dirname "$(readlink -f "${0}"""
cd "${HERE}"
export MONO_WINFORMS_XIM_STYLE=disabled; GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc exec mono "${HERE}//Solver.exe" "$@"
I use smath with a light default theme from /usr/share/themes/.
WINFORMS option also fixes ubuntu/debian crash.
#6 Posted: 2024/9/16 09:41:19
usamakhan
usamakhan
Thanks Overlord, the thing is that developers should move from MONO to dotnet6/7/8 these are available in all Linux distributions! Recently a popular photo editor Pinta moved from MONO to dotnet8 ...similarly calcpad also did that & is very usable in Linux
Davide Carpi 2024/9/16 13:31:00
#7 Posted: 2024/9/16 16:12:13
Actually, not every distribution has dotnet in their repository.
Some major ones like fedora or ubuntu have it, but rest doesn't.
#8 Posted: 2024/9/17 07:33:38
usamakhan
usamakhan
overlord, I did that (customised run script) but Rayleigh theme was not loaded. I tested location / files ...content is there but theme is not loaded. Any suggestions?
#9 Posted: 2024/9/17 18:15:18
If smath window is light themed, it should have ben loaded.
As far as I know, mono2 applications doesn't accept themes designs except colors.
