Roark Mathcad interactive Book
Roark Mathcad interactive Book - Messages
#1 Posted: 2019/9/20 04:53:14
pierre
pierre
2 likes in 17 posts.
Hi there,
As was wondering if their is any way to open the "Roark’s formulas for Stress and Strain" mathcad handbook?
Roark's Formulas Stresses Strain 6ed Mathcad Handbook (same as the ZIP archive).rar (9.4 MiB) downloaded 671 time(s).
#2 Posted: 2019/9/20 05:49:21
1,443 likes in 2,935 posts.
They are .mcd binary files, there's no way to open them because are encoded in a prorietary format.
#3 Posted: 2019/9/20 06:01:15
pierre
pierre
Ok,
Thank you a lot for the fast answer.
#4 Posted: 2019/9/20 08:10:12
I was wondering if there is any way to open the "Roark’s formulas for Stress and Strain" mathcad handbook?
My answer is NO ... Smath is not a Mathcad clone.
What I have from Mathcad 8 Pro up to Case 12.a
All that stuff are only formulas, but not only formulas.
Each example, thus each eventual application case
are base on the solve bloc Given/Find [linear]
Smath does have such coded solver.
Very many Mathcad Given/Find have been solved in Smath
via its own solver. Best example is Frobenius, Quaternion ...
I see no problem making an Smath Roark, quite a project.
It should be no problem adapting the units ISO [metric].
Put the stuff up to Case 5a in Smath document,
attach in this Forum for eventual collaboration.
#5 Posted: 2019/9/20 10:24:36
Smath does not have ...
#6 Posted: 2019/9/20 20:52:01
1,554 likes in 1,864 posts.
It is possible, but you need to convert all mcd files to xmcd format. You can do it manually using Mathcad 11. After that you can try open xmcd files in SMath Studio.
frapuano 2019/9/21 02:51:00
#7 Posted: 2019/9/20 23:37:10
That stuff is Mathsoft from Mathsoft, i.e: from Mathcad.
The collab has that stuff, just to be converted Given/Find.
Smath is not going to convert Given/Find.
That bloc is Mathsoft property.
I'm saying that because you are suggesting Smath will run.
#8 Posted: 2023/5/25 12:03:02
pierre
pierre
Dear all,
I took some time rewriting the roark for Smath,
It is not finished yet, and I am still working on it on my spare time, as it improve both my understanding of smath, and structural calculation.
Many calculations can be done in other way, and if pple find a faster, or more interesting way to solve some equation/problems, i would be really interested, and integrate it.
roark v0.1.7z (1.52 MiB) downloaded 766 time(s).
One last question:
My aim is to make an handbook, how can i perform this?
Thankyou,
Pierre
#9 Posted: 2023/5/25 14:46:00
Hello Pierre,
Simply attach your *.sm document to read at opening.
Thanks, Jean.
#10 Posted: 2023/5/25 15:18:09
CBG
CBG
78 likes in 312 posts.
Hello
I think the interactive book query can help you
Carlos
#11 Posted: 2023/5/26 04:24:31
1,355 likes in 2,271 posts.
Dear all,
One last question:
Thankyou,
Pierre
The links in your book don't work for me. It seems that batch production of links using the toolbox from the text region utilities plugin don't produce valid links any more.
So you might have to edit the xml file as I had to when I started to create the interactive handbook.
#12 Posted: 2023/5/26 15:02:35
basri
basri
0 likes in 5 posts.
Hi, I am new Smath. I was trying to open Mathcad file (.xmcd). The page went blank. Would you help? Thank you.
