Analog Clock
Analog Clock - A simple animation - Messages
#1 Posted: 2013/7/9 10:24:35
1,443 likes in 2,935 posts.
A simple animation
Best Regards,
Davide
AnalogClock_viewer.7z (355.86 KiB) downloaded 746 time(s).
4 users liked this post
ioan92 2013/7/9 11:21:00, Вячеслав Мезенцев 2013/7/11 13:12:00, Andrey Ivashov 2013/7/10 08:27:00, Fridel Selitsky 2013/7/9 14:27:00
#2 Posted: 2013/7/9 16:51:49
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
AnalogClock1.sm (22.29 KiB) downloaded 1262 time(s).
Davide Carpi 2013/7/9 17:15:00, Andrey Ivashov 2013/7/10 08:27:00
#3 Posted: 2013/7/9 17:20:04
Thank you ber,
this make the script faster and easier to read
Best regards,
Davide
P.S. worksheet updated
#4 Posted: 2013/7/11 05:37:01
Fridel Selitsky
Fridel Selitsky
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
AnalogClock2.sm (21.44 KiB) downloaded 1310 time(s).
Вячеслав Мезенцев 2013/7/11 13:12:00, Davide Carpi 2013/7/11 08:45:00
#5 Posted: 2013/7/11 08:49:18
I see, wonderful
#6 Posted: 2019/7/16 00:08:53
Best Regards,Ber7.
Glorious old vintage, before I joined Smath.
More elegant needles in there ... needs be animated
attach]31143[/attach]
#7 Posted: 2019/7/18 14:24:18
Oscar Campo
Oscar Campo
135 likes in 309 posts.
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to [USERLINK]Razonar[/USERLINK]):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (38.86 KiB) downloaded 1210 time(s).
click_low.wav (171.1 KiB) downloaded 322 time(s).
alarm.wav (891.03 KiB) downloaded 324 time(s).
frapuano 2019/7/18 14:53:00, Alvaro 2019/7/19 02:04:00
#8 Posted: 2019/7/19 02:25:06
1,123 likes in 1,795 posts.
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
frapuano 2019/7/19 05:23:00, Oscar Campo 2019/7/19 17:39:00
#9 Posted: 2019/7/19 18:15:08
Oscar Campo
Oscar Campo
Thanks for your suggestions Also I considering the seconds in the movement of the minutes hand for a more realistic appearance.
I've updated the file and I uploaded the new one, you can check it here.
