percent symbol in math equations
percent symbol in math equations - Messages
#1 Posted: 2017/1/23 00:03:56
RickH
RickH
0 likes in 5 posts.
Greetings,
I am curious about the operation of the percent "%" symbol.
If I add, for example, 1+100%=..., it gives the warning "units don't match".
I would expect it to return either 2 or 200%.
I only installed the program a few days ago, so maybe I am misunderstanding the operation of the % symbol. The program is very nice - just trying to figure out the details for input, etc.
Thanks!
#2 Posted: 2017/1/23 04:19:10
1,308 likes in 2,221 posts.
Can't reproduce that with 0.98.6179.
Make sure the % symbol is in blue italic (recognized as a unit).
Type 1+100% TAB =
The tabulator key is used to confirm the selection in the dynamic assistant.
In SMath Studio % is nothing else than a representation of the number 0.01
#3 Posted: 2017/1/23 09:50:58
Type X:=1.23456789*[in the place holder: insert % from drop down unit menu]
check result X=0.0123456789
#4 Posted: 2017/1/23 14:52:57
RickH
RickH
0 likes in 5 posts.
Thanks for the replies.
I believe my problem was replacing "Metric" with "Imperial" in the settings.inf file (OutputUnitsSystem variable).
I was trying to force the output units to be Imperial, which was working, but apparently it has some effect on the use of the % symbol.
Anyway, I think changing to Imperial in the .inf is not technically a supported or approved method.
So I changed my OutputUnitsSystem back to Metric and it works fine.
Thanks again.
#5 Posted: 2022/3/29 14:03:05
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 177 posts.
Greetings!
To the best of my knowledge, you should be able to redefine the 「%」 from 「dimensionless」 to a 「number」 of value: 0.01; keypress the following at the top of your worksheet:
'%:1/100
(NOTE: I currently have the settings.inf file modified to Imperial units 「OutputUnitsSystem=Imperial」 and % appears to behave as expected when it is redefined to 0.01)
-Kenny Lemens, P.E.
#6 Posted: 2022/3/29 20:33:12
