Newton method
Newton method - Messages
#1 Posted: 2023/4/8 16:07:23
Valery Ochkov
Valery Ochkov
66 likes in 690 posts.
I cannot use the roots function and must use one old good simple method by Newton.
What can you say about it?
Newton-Eng.docx (1.07 MiB) downloaded 862 time(s).
Martin Kraska 2023/4/9 08:50:00
#2 Posted: 2023/4/9 08:56:19
1,355 likes in 2,271 posts.
Very nice.
I had problems when reproducing your 2D version. Depending on initial guess I got errors "requested matrix element does not exist". The situation seemed to improve a little by pre-allocating the vectors X and Y yet it didn't become really robust.
So instead of assigning to j+1 elements I used augment() to add new points to the iteration history.
This is the original version:
Newton2D.sm (21.4 KiB) downloaded 1360 time(s).
And this is the modified version.
Newton2Da.sm (19.03 KiB) downloaded 1472 time(s).
#3 Posted: 2023/4/9 14:27:18
... can't find 2nd root
2nd root confirmed exact.
Solve(f,q,x0,x1,TOL) Copy.sm (162.62 KiB) downloaded 1484 time(s).
#4 Posted: 2023/4/9 14:33:35
598 likes in 1,380 posts.
Tried to solve your functions with al_nleqsolve().
Newton.sm (13.85 KiB) downloaded 1400 time(s).
#5 Posted: 2023/4/9 18:19:38
1,123 likes in 1,795 posts.
Another way, keeping the mathematical formulation and the iteration algorithm separate. As here.
Newton2Da.sm (13.34 KiB) downloaded 1519 time(s).
#6 Posted: 2023/4/10 12:25:58
Thanks Alvaro, added to my next Samples visit.
Take care ... Jean
#7 Posted: 2023/4/10 16:21:38
Actually, you can.
#8 Posted: 2023/4/10 20:29:31
An old vintage in Smath ... two examples.
Take care Valery ... Jean.
Solve_roost f1(x,y). f2(x,y).sm (27.42 KiB) downloaded 1484 time(s).
#9 Posted: 2023/4/11 14:21:16
Two variations added.
Newton2Da. v2.sm (38.35 KiB) downloaded 1470 time(s).
Newton2Da. v2.pdf (152.11 KiB) downloaded 961 time(s).
sergio 2023/5/3 14:29:00
#10 Posted: 2023/5/3 00:37:31
Valery Ochkov
Valery Ochkov
From my future article
Если уравнений не два, а три, то матрица Якоби будет состоять из трёх строк и трёх столбцов. При этом графически отображать решение придётся не двумя кривыми, а тремя поверхностями на 3D-графике, причём их взаимное пересечение и будет отмечать решение (задание читателю).
Слабо!
Alvaro 2023/5/3 03:21:00
#11 Posted: 2023/5/3 12:02:25
You may find this Treasury useful/productive.
Solve(f,q,x0,x1,TOL) Copy.sm (300.16 KiB) downloaded 1501 time(s).
