Maxima - Solving Systems
Maxima - Solving Systems - Messages
#1 Posted: 2014/2/10 23:33:45
sefc
sefc
0 likes in 4 posts.
I am very new to Smath Studio and programming in general. I have been able solve systems directly in Maxima, but am having difficulty doing it through the plugin for Smath. Could someone please give me some tips for how to solve a simple system such as a car accelerating from a stop?
Say I know the distance and time that a car accelerates and I want to determine the acceleration and velocity. Obviously this is a very simple example to do by hand, but I want to understand the technique for how to solve this in Smath using Maxima.
Equations:
d=1/2*a*^2
v=sqrt(2*a*d)
Knowns(t,d)
Unknowns(v,a)
Thanks for the help!
#2 Posted: 2014/2/11 03:56:40
Just look at the SMath Active Book by Martin Kraska and you will find under Maxima plugin the answer. For instance, you can use Algsys() function
[MATH=eng]L:Algsys(mat(d≡1/2*a*t^2,v≡sqrt(2*a*d),2,1),mat(v,a,2,1))[/MATH]
[MATH=eng]Assign(L)=sys(sys(2*abs(d)/abs(t),2*d/{t^2},2,1),1,1)[/MATH]
[MATH=eng]v={2*abs(d)}/abs(t)[/MATH] [MATH=eng]a={2*d}/{t^2}[/MATH]
Davide Carpi 2014/2/11 05:05:00
#3 Posted: 2014/2/11 12:46:40
sefc
sefc
0 likes in 4 posts.
Great, thank you so much omorr!
#4 Posted: 2014/2/11 20:53:18
sefc
sefc
0 likes in 4 posts.
I went home and tried using that function tonight and keep getting an error message that the d and v are "not defined". Like I said, I am new to this and I am not quite sure what my mistake is. I really appreciate the help!
#5 Posted: 2014/2/11 20:59:34
1,355 likes in 2,271 posts.
That is because you try to get a numeric result. If you use -> (evaluate symbolically) then you get the correct result.
You also can switch evaluation mode via context menu (right mouse button), entry "Optimization"
rafaeljr 2018/4/9 19:39:00
#6 Posted: 2014/2/12 00:35:08
sefc
sefc
0 likes in 4 posts.
Wow, thank you both so much! That was super helpful. I need to go brush up on the basics.
Thanks again!
