lookup fuction
lookup fuction - Messages
#1 Posted: 2023/3/6 05:02:40
soomoon
soomoon
1 likes in 42 posts.
I would like to have a function like lookup (vlookup, hlookup) in smath.
thank you.
João Felipe Seráfico Melo 2023/3/6 10:09:00
#2 Posted: 2023/3/6 05:45:04
7 likes in 62 posts.
findrows function within Special Functions plugin is what you're looking for, soomoon
#3 Posted: 2023/3/6 08:36:22
Find Index Key Code is lot more powerful.
Assume your Customer wants more information from his bar diameter
you can give all pertaining informations ...
Add price column, material, delivery ... etc.
bar size Findndex KeyCode.sm (10.33 KiB) downloaded 1128 time(s).
#4 Posted: 2023/3/6 09:14:07
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
bar size.sm (9.63 KiB) downloaded 1157 time(s).
João Felipe Seráfico Melo 2023/3/6 10:05:00
#5 Posted: 2023/3/6 10:05:04
Jean, your example shows EXACTLY what findrows does.
#6 Posted: 2023/3/6 17:23:05
Yes for that simple application.
FindIdx(V,x,col) gives me more for advanced Engineering works
Thanks for the observation.
#7 Posted: 2023/3/6 23:46:16
598 likes in 1,380 posts.
https://en.smath.com/forum/yaf_postst673_lookup.aspx
Check thread above. You may find it useful.
You can look forum for your questions by searching too.
Searching may result with a ready answer to a question.
#8 Posted: 2023/3/7 12:30:02
NDTM Amarasekera
NDTM Amarasekera
findrows() function revisited.
As a part of a project undertaken to study flows of some perennial streams in Sri Lanka,
a particular stream, located far away from Colombo, was selected and a Rating Table (RT) was
prepared relating water levels to flows. This process took a few years so that the
data would almost cover reasonable range of depths for practical reasons, excluding severe floods.
During this period, an electronic device was also constructed to measure water levels (WL) and
transmit as digital signals to control station in Colombo.
However, the numerical values of transmitted WL had more than 6 decimals,
whereas the Rating Table (RT) was calibrated only to 2 decimals. Hence, initially WL values
had to be refined to 2 decimals for use with RT values.
Earlier a vlookup function which was posted in the forum was used, but it took a long time to process
But when the findrows function was available, data processing was dramatically fast.
Both Excel and SM files must be in the same folder.
Cheers
1.July WL&RT.xlsx (29.52 KiB) downloaded 886 time(s).
Find_Flows-R1.sm (26.11 KiB) downloaded 1220 time(s).
Find_Flows-R1.pdf (234.55 KiB) downloaded 782 time(s).
Mark R Harris 2023/3/8 16:34:00
