Edit a chart
Edit a chart - How to insert numbered points in a graph - Messages
#1 Posted: 2020/1/21 15:49:24
Ale16595
Ale16595
0 likes in 35 posts.
Hello to all.
I have traced these three functions, that depend on time, on the graph.
How can I insert numbered points, superimposed on the traced functions, so that the same numbering corresponds to the same instant of time?
To be clear, I should do something like the following figure …
This is the .sm file: CALCOLI TESI manovra.sm (69.86 KiB) downloaded 976 time(s).
thanks in advance for the help
#2 Posted: 2020/1/21 16:53:21
127 likes in 342 posts.
using some good tips posted by Jean, you could do this:
CALCOLITESImanovra_s.sm (78.32 KiB) downloaded 983 time(s).
I preferred to refer to actual times and not to anonymous labels; however you can use the same methodology more easily
Ale16595 2020/1/22 08:32:00
#3 Posted: 2020/1/21 18:39:09
Can you trace these functions from the previously doctored document.
Why jump ship [new thread] from suite to suite ?
#4 Posted: 2020/1/22 14:36:11
Easy ... take the DE that I doctored before
there may be some sanity wrt the other two graphs.
Ale16595 2020/1/22 15:03:00
#5 Posted: 2020/1/23 09:04:58
What's next past the DE ?
CALCOLI TESI manovra ... What Next.sm (70.75 KiB) downloaded 1017 time(s).
