While loop question
While loop question - Messages
#1 Posted: 2023/4/6 18:28:44
Razvan
Razvan
0 likes in 2 posts.
Hello everybody,
I'm really new to Smath and i am having an issue with the while loop. How can you write multiple conditions for your while loop. While a>b && b>c && c>d.
Would really appreciate some input.
#2 Posted: 2023/4/6 19:44:47
How can you write multiple conditions ...
If you want to piece wise plot conditional ...
if/otherwise ... as any as you want to condition.
From the directed visit Samples, iterative is bidirectional.
Or multiple conditional Golden ratio
More advanced conditional is generally Bolean... Example attached.
Show something of your Creation.
Critical Triplet Demo.sm (16.26 KiB) downloaded 1213 time(s).
#3 Posted: 2023/4/7 00:10:14
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 180 posts.
Greetings!
Hello everybody,
In the boolean toolbar, you will notice "AND" and "OR" operators, denoted as ⋀ & ⋁ (respectively).
On that note, to specify more then (1) command under your while loop; utilize the "line(" command.
As such, you can copy and paste the following:
line(a:20,b:5,c:1,d:0,while(((a>b)&(b>c))&(c>d),line(cc+(b:b+5)),a:a+1,d:b*(-1),3,1)),stack(a,b,c,d),6,1)=#
I hope this is of Good Help;
- Kenny Lemens, P.E. ᵂᴵ
#4 Posted: 2023/4/7 02:28:10
Razvan
Razvan
0 likes in 2 posts.
Cheers, thanks!
#5 Posted: 2023/4/7 16:12:52
... Bolean composite style.
#6 Posted: 2023/4/7 16:33:31
598 likes in 1,380 posts.
There are also;
ltlt(), altle(), alelt(), a≤blele(), a≤b≤c
gtgt(), a>b>c
gtge(), a>b≥c
gegt(), a≥b>c
gege(), a≥b≥c
These functions are part of Custom Functions plugin.
Unfortunately, it supports only three arguments.
Despite that, some boolean expressions may shorten drastically.
line(a:20,b:5,c:1,d:0,while((gtgt(b,a,c))&(c>d),line(cc+(b:b+5)),a:a+1,d:b*(-1),3,1)),stack(a,b,c,d),6,1)=#
João Felipe Seráfico Melo 2023/4/8 14:45:00
#7 Posted: 2023/4/8 10:17:59
1,443 likes in 2,935 posts.
I've never thought about it, but I think that maybe I can add set of functions with unlimited arguments (>1), gt(#) ge(#) lt(#) le(#)
João Felipe Seráfico Melo 2023/4/8 14:45:00, overlord 2023/4/8 16:19:00
#8 Posted: 2023/4/8 14:08:03
... adapt the out maths to your project.
#9 Posted: 2023/4/8 16:20:10
Would unlimited versions be mixed or same boolean expression?
#10 Posted: 2023/4/8 17:52:11
... interesting, however very multiple-specific.
#11 Posted: 2023/4/8 21:22:45
1,123 likes in 1,795 posts.
In addition to gt(#) ge(#) lt(#) le(#), some notes about a relseq function.
relseq.sm (24.53 KiB) downloaded 1171 time(s).
Mark R Harris 2023/4/9 00:59:00, sergio 2023/4/10 06:28:00
#12 Posted: 2023/4/11 06:03:38
that way, it would be same boolean
lt(a,b,c,d,e,f)=a<b<c<d<e<f=(a<b)&(b<c)&(c<d)&(d<e)&(e<f)
That's a good concept, I think that probaly it's feasible. I'll give it a try.
João Felipe Seráfico Melo 2023/4/11 08:34:00, Alvaro 2023/4/11 10:04:00
#13 Posted: 2023/4/13 02:45:33
... I'll give it a try.
Hi Davide. Something like this other?
#14 Posted: 2023/4/18 07:23:00
this maybe?
also, prefix/postfix functions can be made for unlimited arguments.
I've tried something like postfix(F,x,y) but it isn't really user-friendly (e.g. it can't be used on the LHS of an assignment because it overvrites the postfix() function itself)
Alvaro 2023/4/18 12:22:00
#15 Posted: 2023/4/18 12:25:44
... this maybe? ..
Hi Davide. Great implementation. But I'm thinking in ways to write set union a U b, intersection, function composition like f o g (x) := f(g(x)), logical binary operators like implies, iif and similar stuff.
