Small imaginary number in result
Small imaginary number in result - Messages
#1 Posted: 2010/3/25 13:51:39
maweilian
maweilian
5 likes in 103 posts.
I am using version 0.87.3728. I performed the calculation below:
As you can see the answer should be simply -0.4063804, but Smath added an unwarranted, very small imaginary number to the answer.
#2 Posted: 2010/3/25 17:49:31
Hello Will,
I tried this on 0.87 stable (0.87.3692)
Could you double check it. This looks to me Ok, although quite different from your result.
I again forgot to bring 0.87 Beta with me, sorry. I'll check this out tomorow.
#3 Posted: 2010/3/25 20:01:50
maweilian
maweilian
Hello Will,
I downloaded and installed the stable version (0.87) and it also worked fine for me.
So this must be a bug in 0.87 Beta.
Thanks for the help.
#4 Posted: 2010/3/25 21:19:50
You are welcome ,
You might be right. I mentioned some odd behavior wnen using trigonometric fuctions with units arguments in the first Beta. Andrey fixed that. It might remain some unfinished work on the same issue.
#5 Posted: 2010/3/26 07:24:13
Hello Will,
Here is the 0.87_3728 version of your example made on my computer.
It is again different than yours but closer to mine previously made on 0.87 Stable.
I think that the imaginary part could be freely neglected here (less than 10^(-15). If the SMath would have had the system of representing results with the given precision, this imaginary part would have not been presented here. Therefore, I suggest you to use just the real part of the results.
On the other hand I am not sure why our results are so different?
#6 Posted: 2010/3/26 15:46:04
captainblack
captainblack
0 likes in 13 posts.
Hello Will,
Note that you had the angle mode set to degrees and omorr has his set to radians (0.87 seems to return a real result in either mode)
CB
#7 Posted: 2010/3/26 16:21:19
Oh yes, thank you captainblack. I just forgot to check that out . It did not come to my mind, sorry.
#8 Posted: 2010/3/29 15:26:47
maweilian
maweilian
Hello Will,
Radovan,
As CB said, I was performing the calculation in degrees, but, as you have demonstrated, the inclusion of an imaginary component occurs regardless of whether degrees or radians are used. In this case, I did end up using the real component. However, since I use Smath to clearly document calculations, the results produced by Smath in this case are unacceptable since it introduces unnecessary clutter to what should be a straightforward calculation. So, I would most certainly add this problem to the "to be fixed" list for 0.87 Beta.
Sincerely,
Will
#9 Posted: 2010/3/29 15:50:04
Hello Will,
I suppose that SMath should have Zero and Complex treshold in order to avoid these situations. This way would overcome the mentioned problems.
#10 Posted: 2010/3/29 18:02:03
2,340 likes in 4,041 posts.
Agree with you. Will implement this.
