Modeling an Air Defense System: Ballistic Target Interception
Modeling an Air Defense System: Ballistic Target Interception - Messages
#1 Posted: 2026/3/31 15:01:53
1,554 likes in 1,864 posts.
It’s a mathematical model of an Air Defense System intercepting an unguided ballistic target, complete with an animated XY-plot.
Here is a quick overview of the math and physics inside the model:
- The Target (Blue trace): Modeled as a projectile launched at 700 m/s at a 60° angle. Its flight is governed by 2nd-order ODEs accounting for gravity and aerodynamic drag (using an exponential air density model based on altitude).
- The Missile (Red trace): Launched from a distance of 15 km with a constant speed of 350 m/s. It uses a continuous "Pure Pursuit" guidance law, meaning its velocity vector is constantly updated in the ODE to point directly at the target's current coordinates.
- The Core Logic: Instead of calculating the trajectories separately or using discrete loops, both the target's physics and the missile's guidance logic are unified into a single system of differential equations. The entire engagement is solved simultaneously using the built-in rkfixed solver.
- Launch Delay: The missile equations include a launch delay condition (t0​ = 8 s) so the missile waits for the target to enter the optimal engagement zone.
I've attached the .sm document along with a GIF animation of the result.
You can play around with the launch delay (t.0), missile speed (v.r), or launch angle to see how the interception trajectory changes.
air-defense.sm (26.84 KiB) downloaded 427 time(s).
air-defense.pdf (86.6 KiB) downloaded 336 time(s).
Edited 2026/3/31 21:21:41
4 users liked this post
ioan92 2026/3/31 17:55:22, Valery Ochkov 2026/3/31 23:22:19, overlord 2026/4/1 09:31:46, santiago 2026/4/9 23:51:13
#2 Posted: 2026/4/2 10:45:34
Valery Ochkov
Valery Ochkov
66 likes in 690 posts.
You can learn about the problem and its solution from the article​
V.F. OCHKOV, I.E. VASILEVA
APPLICATION OF DIFFERENCE SCHEMES TO DECISION THE PURSUIT PROBLEM
https://ia.spcras.ru/index.php/sp/article/view/4041/2619
