faculty operator crashes smath
faculty operator crashes smath - Messages
#1 Posted: 2013/8/24 06:25:32
1,355 likes in 2,271 posts.
see image. You can choose [Continue] from the error dialog and then have to remove (blindly) the region where you typed the offending contents. Version 0.96.4909, Win7
#2 Posted: 2013/8/25 23:01:53
rmix22
rmix22
3 likes in 15 posts.
I am using the same SMath version but Win XP SP3 and cannot duplicate the crash you describe. If I follow your steps a get (a+b)!= and depending upon if a and b would have been assigned values either an error a sof "a" being unknown or the correct numeric result.
Martin Kraska 2013/8/26 01:24:00
#3 Posted: 2013/8/26 01:22:41
Thanks, You are right, there is a bug in the bug report. Must be a*b instead of a+b.
after a*b typing space extends the underline cursor to the expression a*b. When you then type !, the underline shrinks to b! and typing = causes the crash.
#4 Posted: 2013/8/26 04:59:17
1,443 likes in 2,935 posts.
this is confirmed
best regards,
Davide
#5 Posted: 2013/8/26 05:02:31
rmix22
rmix22
Yes, I can confirm that bug now.
#6 Posted: 2014/3/23 07:05:47
Bug seems to be fixed, cannot reproduce it any more in 0.97.5189.
