Difference between symbolic and numeric calculation on imaginary unit
Difference between symbolic and numeric calculation on imaginary unit - Expression (1/i)*(1/i) , symbolic result "1", numeric result "-1" - Messages
#1 Posted: 2012/11/28 05:11:37
Gossage
Gossage
0 likes in 1 posts.
I try to calculate "(1/i)*(1/i)" either in symbolic and numeric method and I get "1" and "-1" respectively.
Note that this problem does not appear with the expression "(1/i^2)".
In attachment a simple .sm file to illustrate the bug.
Best regards,
Gossage
bug_imag.sm (2.37 KiB) downloaded 1246 time(s).
#2 Posted: 2012/11/28 12:57:33
Hello Gossage,
I just can confirm this.
Have no explanation of this, except that this is definitely a bug.
#3 Posted: 2012/11/28 18:49:45
Diego Jarrín
Diego Jarrín
7 likes in 14 posts.
There are other problems with the symbolic interpretation.
Did you tried to compute sin(-4*pi/3) and sin(2*pi/3) in the numeric and symbolic methods?
symbolictrouble.sm (17.55 KiB) downloaded 1219 time(s).
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
#4 Posted: 2012/11/29 17:11:21
1,355 likes in 2,271 posts.
Hi
These examples just illustrate the known fact that the SMath symbolic engine is unreliable. Currently, it is not safe to use it. The Numeric engine seems to be more reliable, thus it's usage can be recommended.
What to do if you need symbolic calculations? There is a plugin that communicates with a dos version of maple and is much more powerful than the SMath internal engine. However, the plugin is not localization-safe, i.e. if argument delimiter is set to semicolon ;
I would like SMath to be an 2D document interface to maxima, which has all the math (including units) one would need but lacks the MathCad like document interface.
Best regards, MK
#5 Posted: 2013/4/30 18:18:04
2,340 likes in 4,041 posts.
Fixed.
Radovan Omorjan 2013/4/30 18:21:00
