How to apply initial conditions in second-order differential equations
How to apply initial conditions in second-order differential equations - How to apply initial conditions in second-order differential equations - Messages
#1 Posted: 2025/12/7 03:59:55
kimkim
kimkim
0 likes in 9 posts.
The solution to the second-order differential equation has been obtained as follows.
If we want to find the solution by applying the initial conditions y(t)=0, y'(t)=0,
what should I do in the following steps?
thank you for your help.
Edited 2025/12/7 06:53:24
#2 Posted: 2025/12/7 09:07:00
StvMath
StvMath
44 likes and 1 dislikes in 71 posts.
Once you've got y(t) you could simply do the following:
kimkim 2025/12/7 21:41:13
#3 Posted: 2025/12/7 12:54:45
1,355 likes in 2,271 posts.
If you don't need the function v(t), you can specify the initial conditions directly: (example 10.2 in https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath)
sergio 2025/12/7 17:07:45, kimkim 2025/12/7 21:41:18, ioan92 2025/12/9 10:52:27
